Long timeouts for stale PPPoE connections
- Re: Long timeouts for stale PPPoE connections
- « Previous
- Next »
07-10-2013 9:52 AM
No loss of sync just PPP session, which took nearly 9mins to re-connect to a different gateway , this has happened in the past also when it was confirmed as being your side , I can switch gateways without such a long time out even after a power cycle of the router which has an uptime of 52 Day(s) 7 Hour(s) so no loss of power to it either
Message 76 of 78
(987 Views)
07-10-2013 10:02 AM
The long time it is because it was an untidy disconnect. Something on the exchange side still thinks you are connected. If you are using a TG582 there is a setting you can apply to prevent this.
Kelly Dorset
Ex-Plusnet Jobsbody
Ex-Plusnet Jobsbody
Message 77 of 78
(987 Views)
07-10-2013 10:21 AM
I use a Billion 7800 router, Exchange side, could be possibly where the underlying cause is then, as it's unlikely to be between the FTTC cab and the modem
There again the "Termination by server side (NAS) Modem" event your side , doesn't really provide much info to pin point what was responsible, But looking at the ping monitors and there is one that mirrors the same disconnect but at a slightly different time
So this could indicate something plusnets side or a BT core link that supplies both our connections My guess would be that the gateway shed some of it's load
a rudimentary load balance maybe
Message 78 of 78
(987 Views)
- « Previous
- Next »
