Long phone and sms wait
zaaxuk
After waiting 15 min I gave up. The AA answered in 1 min why can PlusNet support?
10 REPLIES 10
Fixes: 334
Re: Long phone and sms wait
What is your issue, @zaaxuk  - maybe the Community can help?
Tina11192
Fixes: 18
Hi @zaaxuk I tried calling you but I couldn't get through or leave a voicemail.
Can you please expand on your query and reason for contacting Plusnet so that we can support you further.
Look forward to hearing from you soon
Cri Ignatti
zaaxuk
Trying to get my 90 year old fathers plusnet line checked as youtube keeps buffering, how do i do this?.
Fixes: 334
does everything else work as expected? If you think there is a problem, try the auto-bot approach first:
If the phone test passes, report a broadband problem via: https://www.plus.net/help/report-a-problem/broadband/
The above assumes you still have 'normal' landline connection - if you have a SOGEA (internet only) one the only option is to call Plusnet - 0330 123 9123
zaaxuk
Youtube (an others on his TV) is buffering. When I try the autobot it just does MY plusnet connection which is pointless
Fixes: 334
Ah, so it is a TV issue, not a broadband one. While you are there, see what happens if you try YT on a laptop, if you have one.
Tina11192
Fixes: 18
Hi @zaaxuk thanks for getting back so swiftly, please, can you DM me a contact number so that I can do an intrusive line test for you.
Cri Ignatti
zaaxuk
Both. My laptop buffers, as does his new 56" TV, and his TV is connect directly to hub 1. My laptop does not buffer when it used my phone's 4g hot spot
Fixes: 334
@zaaxuk OK - I suggest you do as @Tina11192  suggests and PM your fathers account details to her, so she can test the connection.
zaaxuk
PM'ed you.
City Fire and Candent (Gas) are have his road up for the 5th time this year, I bet they have disturbed the lines.
