Login
Selkirk
Login
Every time I use the Forum I need to login, I ticked the little box to keep me logged in which makes no
difference, any help?
James
Re: Login
I think you're having the same problem that I used to.
You'll need to delete your temporary internet files under your internet explorer options.
Bear in mind though, that this might result in your losing some of your other saved settings or passwords.
RobDickson
Re: Login
How about just deleting any PlusNet cookies? The process to do this is different in IE6 and IE7.
Alternatively, use CCleaner.
