Login problems
HaydnExport
Login problems
Hi i am having problems loging in to my account  , you can login fine on the forum  Crazy  Any idea's?
Mand
Re: Login problems
Are you still having problems? Seems to work fine from here.
HaydnExport
Re: Login problems
Yes thanks, bit of a mystery , left it for a couple of hrs and it worked straight away  Crazy
Mand
Re: Login problems
Strange indeed. I'll get someone to check over the portal servers, could be that one is a little poorly.
