Login Security
Login Security
This question has probably been asked before, if so I apologise.
Is there anyway to change the name that I use to login to my FTP account?
It just doesn't seem very secure that everyone can tell what your FTP login name is.
1 REPLY
Re: Login Security
As it's your plusnet account name then no.
There is a long winded (i.e. manual process by PN) way to change your account name which some did after the webmail issue. You will you need to raise a ticket for info.
