Login Security
- Re: Login Security
Login Security
11-09-2007 4:12 PM
This question has probably been asked before, if so I apologise.
Is there anyway to change the name that I use to login to my FTP account?
It just doesn't seem very secure that everyone can tell what your FTP login name is.
Message 1 of 2
(814 Views)
1 REPLY 1
Re: Login Security
11-09-2007 4:37 PM
As it's your plusnet account name then no.
There is a long winded (i.e. manual process by PN) way to change your account name which some did after the webmail issue. You will you need to raise a ticket for info.
Message 2 of 2
(264 Views)
