Logging out of router home page
- Re: Logging out of router home page
24-11-2012 12:39 PM
This probably sounds really stupid. Logging out normally requires logging out somewhere physically. I don't see anywhere to do this when logging onto the router. Am I being really really thick
5 REPLIES 5
24-11-2012 1:17 PM
I don't use the Plusnet supplied router but my Asus RT-N56U router certainly has a log out facility, not that I ever bother to use it.
Message 2 of 6
(3,573 Views)
24-11-2012 1:56 PM
It is a missing Feature of the plusnet firmware I would guess, if you mean the TG582n. Version 8.4.4.J only has switch user but you aren't logged out. So it has a login page that has a temporary cookie for security so we have to manually type the login each time but we can't logout.
So if I leave my pc for 5 minutes after logging in to the router, anything could happen if a family member decided to play around. Not tested it but think it stores that I am logged in cookie for 10 minutes, so a 10 minute window of opportunity.
FTTP 500 regrade from Tues 28th November
Message 3 of 6
(3,573 Views)
24-11-2012 7:19 PM
Yes, you can't logout, just close the window. Even that doesn't log you out but after a period of inactivity the session cookie expires and users have to login again.
David
Message 4 of 6
(3,573 Views)
24-11-2012 10:17 PM
How about deleting the cookie, that should log you out (if it really is cookie based).
That's RPM to you!!
Message 5 of 6
(3,573 Views)
26-11-2012 4:28 AM
Try closing the browser and then re-opening it, and see if you can get straight back in without a login!
Message 6 of 6
(3,573 Views)
