Logging into PlusNet/Metronet Portals
- Logging into PlusNet/Metronet Portals
05-10-2007 11:44 AM
Are there some authentication issue?
I cant login with any of our accounts at the moment
Message 1 of 8
(2,100 Views)
7 REPLIES 7
Re: Metronet Portal
05-10-2007 11:46 AM
I'm experiencing the same problem.
I'll get this raised ASAP.
Message 2 of 8
(792 Views)
Logging into PlusNet Portal
05-10-2007 11:47 AM
Anyone else having trouble logging on, or is it just me?
Trying to log using 'hunthome' and usual password and getting an 'invalid username and password' error. Unless I've typed the password incorrectly (sure I haven't as I've tried 10 times now), or my parents have changed it (which is highly unlikely).
Odd .. I'll try it again later.
Message 3 of 8
(792 Views)
Re: Logging into PlusNet Portal
05-10-2007 11:48 AM
Yep, me too.
Glad to see it's not just me
Message 4 of 8
(792 Views)
05-10-2007 11:50 AM
and me
Message 5 of 8
(792 Views)
Re: Logging into PlusNet/Metronet Portals
05-10-2007 11:55 AM
Moderators Note
Two threads on issues logging in to portal merged.
Jonathan
aka Chilly
Jonathan
aka Chilly
Message 6 of 8
(792 Views)
05-10-2007 11:58 AM
Hi Guys,
Thanks for your patience on this one.
we managed to raise 2 P1's simultaneously and the issue has now been fixed.
As ever, apologies for any inconveniences that this may have caused.
Message 7 of 8
(792 Views)
05-10-2007 12:55 PM
Just to add to James' comments, we encountered a problem with one of our portal back-end servers which is what caused the login problems. We didn't realise this would happen when we restarted a certain server as part of a routine problem fix.
The engineer who performed the work is busy updating the documentation as we speak so that this doesn't happen again.
Message 8 of 8
(792 Views)
