Localhost message
Viking
Localhost message
Can someone see if they can get to the following site?
www.elegantmarketplace.com
For the last 6 weeks or so I cannot. It seems to go there and then redirects to 127.0.0.1
No other users of the site are seeing this problem. I have checked my hosts file which is empty and I'm not using the plusnet filters. I've also tried using different DNS servers. Nothing works
I can access the site if I do so via a vpn, so I'm thinking maybe it's a plusnet issue?
Its very odd. Any ideas?
8 REPLIES 8
Mav
Fixes: 515
Re: Localhost message
No issue accessing it from a PM connection for me.
Forum Moderator and Customer
mikelahey
Fixes: 12
127.0.0.1 is the local loop-back address pointing back to the PC itself.
This has a whiff of Malware of Browser Hijack IMHO
Can you run a Virus Scan and a scan using Malware Bytes Free edition?
Viking
It happens on all devices. Pcs, tablets, phones. Anyone on my network cannot access that site.
Its very odd. I've also tried different routers.
I just cannot get to that site unless I change my ip via a vpn
Browni
Aspiring Hero
Fixes: 60
Working OK for me as well using a Plusnet connection, I do use Google DNS though.
Mav
Fixes: 515
@Viking
Sorry, forgot to say I also use Google DNS.
Pete11
Seasoned Pro
Fixes: 4
No problem with access here on Google Chrome.
A float tip is pleasing in its appearance and even more pleasing in its disappearance.
Growing old is inevitable...But growing up is optional.
30FTTC06
Fixes: 4
Works ok on google and plusnet here..
dig @212.159.6.9 elegantmarketplace.com
; <<>> DiG 9.10.3-P4 <<>> @212.159.6.9 elegantmarketplace.com
; (1 server found)
;; global options: +cmd
;; Got answer:
;; ->>HEADER<<- opcode: QUERY, status: NOERROR, id: 65524
;; flags: qr rd ra; QUERY: 1, ANSWER: 1, AUTHORITY: 0, ADDITIONAL: 1
;; OPT PSEUDOSECTION:
; EDNS: version: 0, flags:; udp: 4096
;; QUESTION SECTION:
;elegantmarketplace.com.                IN      A
;; ANSWER SECTION:
elegantmarketplace.com. 3600    IN      A       50.116.63.111
;; Query time: 17 msec
;; SERVER: 212.159.6.9#53(212.159.6.9)
;; WHEN: Sun Aug 13 20:31:51 GMT Summer Time 2017
;; MSG SIZE  rcvd: 67
dig @8.8.8.8 elegantmarketplace.com
; <<>> DiG 9.10.3-P4 <<>> @8.8.8.8 elegantmarketplace.com
; (1 server found)
;; Got answer:
;; ->>HEADER<<- opcode: QUERY, status: NOERROR, id: 8469
; EDNS: version: 0, flags:; udp: 512
;; ANSWER SECTION:
elegantmarketplace.com. 3599    IN      A       50.116.63.111
;; Query time: 36 msec
;; SERVER: 8.8.8.8#53(8.8.8.8)
;; WHEN: Sun Aug 13 20:32:06 GMT Summer Time 2017
Legend
Fixes: 254
No problem here, using FireFox and the default PN DNS.
