Linksys X3500 stats access
ByteFight
Hi
Does anyone know how to access the hidden statistic on this type of router gateway?
I want to look at the SNR info and as you can do this on other Linksys products I'm assuming I can do it on this new type of device?
offbeatdave
Re: Linksys X3500 stats access
On the x3000 it is at <IP address of router>/SysInfo.htm
Might be the same on your's?
ByteFight
OBDave thxs I'll try this.
ByteFight
Thx that address worked.
