Linksys WAG54GS (issues resolved) & 21CN performance update
rappmx
Hi folks,
Refer to my rant here: http://community.plus.net/forum/index.php/topic,76490.0.html
After 6 days of no connection and a few unhelpful calls to support I finally decided enough was enough contacted PlusNet to get my MAC key.
Heather was very helpful and pushed this through then I spoke to another helpful fellow, Keith, who told me some settings required for my router.
If you happen to have a Linksys router you'll need to set the following:
Modulation: ADSL2 or ADSL2+
VPI/VCI 'Autodetect': disabled
VPI: 0
VCI: 38
Even though the status shows the VPI/VCI as 0 and 38 autodetected it seems to modulate which causes issues.
Anyway I'm currently a satisfied customer once again and thought I'd pass the info onto anyone else who seems to have having the same trouble.
MM
rappmx
Re: Linksys WAG54GS Issues (resolved -tips here)
I thought I would post my current progress on 21CN so far.
I am connecting at a very stable 3261kbps DOWN / 636kbps UP.
I have moved my router to my master socket and disconnected all other items from the phoneline.
However on speedtest.net I get the following (tested twice):
1) 1.37Mb/s DOWN, 0.5Mb/s UP, Ping 89ms
2) 1.37Mb/s DOWN, 0.5Mb/s UP, Ping 78ms
And on BT Speedtester:
Test1 comprises of Best Effort Test:  -provides background information.
    Your DSL connection rate: 3260 kbps(DOWN-STREAM),  636 kbps(UP-STREAM)
    IP profile for your line is - 2500 kbps
    Actual IP throughput achieved during the test was - 1291 kbps
Any ideas why I seem to be 'capped' at such a low speed?
Ta,
Martyn
scootie
Re: Linksys WAG54GS (issues resolved) & 21CN performance update
http://www.mybroadbandspeed.co.uk/ ;  do a few here
edit.
this is what i just got on 21cn on 2500kbps profile
Today 01:05 2307 kbps (288kB/s) 771 kbps (96.4kB/s) Share
Today 01:04 2298 kbps (287kB/s) 772 kbps (96.5kB/s) Share
Today 01:04 2309 kbps (289kB/s) 768 kbps (96kB/s) Share
edit.
also whats your PN profile you need to login into the member centre to see this https://portal.plus.net/my.html?action=data_transfer_speed
rappmx
MyBroadbandSpeed:
Today 01:18 1372 kbps (172kB/s) 501 kbps (62.6kB/s) Share
Today 01:17 1378 kbps (172kB/s) 494 kbps (61.8kB/s) Share
Today 01:16 1378 kbps (172kB/s) 502 kbps (62.8kB/s) Share
Phone exchange:
    ALMONDSBURY
Estimated line speed:
    2.0 Mbps - Checked on 2009-03-27 00:48:31
Current line speed:
    1500
Current line speed looks low?Huh
UPDATE: I typically use wireless to connect my upstairs machine to the internet so to rule that out I connected my laptop to my router via a network cable. The speed results were identical to the above Sad
MM
scootie
yep thats what holding your thoughput down.
how long since your BT profile went up to 2500kbps. PN's should update within 12hours  of your bt one changing.
if its been over day since your bt one changed then post here and james will kick it tomoro
http://community.plus.net/forum/index.php/topic,75814.96.html
rappmx
Ta chap!
I've posted the results there.
I don't believe my IP profile has changed since I moved here so it's been 2500kbps for around 3~4 years lol!
MM
James
@ MM
I've upped your profile at our end to 2500Kbps.
You should see a bit of an improvement.
scootie
if you still get the same results on speed tests then if you login to your router and just diconnect reconnect the internet(no need to resync) that will pick the new PN profile up
rappmx
Today 18:57 .. 2298 kbps (287kB/s) .. 501 kbps (62.6kB/s)  Share
Today 18:55 .. 2280 kbps (285kB/s) .. 481 kbps (60.1kB/s) Share
Woo that's better!
Thanks muchly... quick question will be BT IP profile increase over time or is 2500 it?
My sync speed is still a stable 3217kbps so would that profile increase to 3000?
Ta,
MM
scootie
Affraid not at that sync speed.
You would need to sync at between these rates 3424 kbps 3968 kbps for 3 days solid with no drop in sync below 3424 before profile update to 3000.
check here for sync rate vs profile table http://www.kitz.co.uk/adsl/IPprofile.htm
rappmx
Shock!
I've just checked my router and my sync speed is 3559kbps!
It's unclear hows long its been at this but I guess my profile will update soon -woot!
Cheesy
