Linksys WAG325N Wireless N Router
- Linksys WAG325N Wireless N Router
17-03-2012 1:11 PM
Can somone help me with a Linksys WAG325N Wireless N Router, I brought this router off ebay a while back and was hoping i could use with my plusnet account to boost the signal as I want a better signal in my workshop outside, I use a laptop out there rigged with a wireless dongle attatched to an old sky dish which is aimed at the house to gain a signal, And I listen to internet radio staions through the laptop, amp, and speakers.
I can't really move the orginal thompson router I got from plusnet any nearer to get a better signal, and I am really thick with routers so need a walkthrough guide, Or failing that can anyone suggest another router with more signal power that goes well with plusnet, The reply i got from plusnet customer support was 'The router we supply is a standard b/g connection which is the standard, unfortunately we cannot supply a more powerful router' Any help would be great. thank you.
David
David
Message 1 of 2
(1,070 Views)
1 REPLY 1
Re: Linksys WAG325N Wireless N Router
18-03-2012 8:21 PM
Sorted it, muddled through and worked it out myself, much more sig.
Message 2 of 2
(302 Views)
