Line upgrade
- Re: Line upgrade
Line upgrade
01-12-2010 9:20 PM
Hi, I have recently signed up to the phone and broadband package with PN. I was just wondering will my current phone line be upgraded to an ADSL/broadband line or will you just continue to use the line currently in place?
Thanks.
Thanks.
Message 1 of 7
(956 Views)
6 REPLIES 6
Re: Line upgrade
01-12-2010 9:33 PM
Welcome to the Forum and PlusNet
I am on about a 40 year old wire and now synching at 16 M on a ADSL2 circuit, does that answer you?
Message 2 of 7
(499 Views)
Re: Line upgrade
01-12-2010 10:00 PM
Well without completely understanding the technical stuff in your post, I'm guessing the answer to my question is "NO"?
Message 3 of 7
(499 Views)
Re: Line upgrade
01-12-2010 10:26 PM
The answer actually is that it should but sometimes it doesn't happen.
Once you are connected then a quick look at the router stats will tell you - if the upstream is 448kbps then you are on ADSL.
If you aren't a ticket requesting the change will be the easiest way and I believe that it only takes a few days to happen.
However given the present snow problem and B T's declaration of their equivalent of a "State of Emergency" it may take a little longer depending on where you live
Message 4 of 7
(499 Views)
Re: Line upgrade
01-12-2010 11:02 PM
Thank you both for you're replies. To change the subject slightly the master socket looks quite old (without a removable front plate for extensions), I know I'm not legally allowed to tamper with this but I remember a few years back in another property I was advised to remove the bell wire (socket 3 on the extension side) to help remove interference from the line and therefore improve the adsl speed, is this still correct or no longer necessary?
Message 5 of 7
(499 Views)
Re: Line upgrade
01-12-2010 11:08 PM
100% correct, remove the Bell wire at both end, your main socket and the far end
Have a look here for the socket types, lots more info, some very technical http://www.kitz.co.uk/adsl/btsockets.htm
Message 6 of 7
(499 Views)
Re: Line upgrade
01-12-2010 11:15 PM
That's great, thanks for your help.
Message 7 of 7
(499 Views)
