Line stat.
- Re: Line stat.
Line stat.
19-03-2013 3:18 PM
Speeds are pretty good but not quite the 80+/- estimated.
Re: Line stat.
19-03-2013 3:20 PM
Re: Line stat.
19-03-2013 3:27 PM
Re: Line stat.
19-03-2013 3:32 PM
I would allow the line to settle and see how things go.
Re: Line stat.
19-03-2013 3:43 PM
Re: Line stat.
19-03-2013 3:44 PM
Re: Line stat.
19-03-2013 3:44 PM
Your line looks like it's running at pretty much maximum speed. Remember the 80Mbps figure is line sync rate. By the time you've added all the overheads for VDSL, TCP/IP, etc then you're down to a real user data throughput of around what you're getting. What's your BT IP profile currently? (from BTW speed tester, run 1st test, then hit Further Diagnostics). Your IP profile will be 0.9679 of your actual sync rate.
Re: Line stat.
19-03-2013 4:02 PM
About the profile, theres a problem. I get "Test Error" when I click on diagnostics.
Re: Line stat.
19-03-2013 4:03 PM
Re: Line stat.
19-03-2013 4:12 PM
Re: Line stat.
19-03-2013 4:15 PM
Re: Line stat.
19-03-2013 4:30 PM
If you do decide to get an unlocked HG612, you'll probably want to read this too.
Re: Line stat.
20-03-2013 9:35 PM
The diagnostic is working and here are the results.
Just wondering, how come I only getting around 73 max where the profile is around 77?
Re: Line stat.
20-03-2013 9:44 PM
Re: Line stat.
20-03-2013 9:56 PM
