Line speed
stewp
Line speed
In the process of moving home. had my phone line re-enabled and went with PlusNet.
Not in my new property atm so bare with me. Left the modem switched on though etc. The line has never had broadband on it before and the phone line has not been in use for about a year. I had a new faceplate fitted a week ago. The guy who did it said that next-door was connected to my line and they shouldn't be (semi-detached house, one line comes in to my house but he's also connected to the box on the exterior of my house). Not sure if this additional info is any use....
Phone exchange: WHITBURN
Estimated line speed:7Mb (This may vary between 5.5Mb and 12Mb)  - Checked on 2013-04-14 11:47:57
Current line speed:3.1 Mb
Seems a little low, any ideas? Thanks for any help Smiley
Fixes: 62
Re: Line speed
Was the guy who fitted the new box from BT
The reason for asking is that I can't think of any reason why a single wire with 4 or more cores can't feed two properties - one pair to each property - and with a pair of semi detached houses it seems a sensible arrangement
I assume that the external box is a BT properly sealed unit
stewp
Re: Line speed
Yes and yes :-)
Fixes: 21
Re: Line speed
What type of face plate was fitted? Was it a standard one?
Are there extension sockets?
Re: Line speed
Hi stewp,
We're currently testing your line and we'll update your ticket as soon as we've got the results.
stewp
Re: Line speed
Ok, let me know if any additional information is required. I will take a photo of the faceplate when I go over later in the week.
Thanks all,
Stewp
dick:quote
Fixes: 68
Re: Line speed
FYI just making sure you've seen the ticket update at 20:34 last night...
 Adam Walker
stewp
Re: Line speed
Will test a new microfilter tonight. I don't have a second modem except for a talktalk branded one. Will that work? Will call when it's set up.
Thanks,
Stewp
Edit. Will use the master socket. I am guessing a micro filter is needed in that too
Fixes: 21
Re: Line speed
You've said you'll use the Master socket, but where have you been plugged in?
You really must use the Test Socket for these checks.
Do you have any extension phone sockets? Anything that is plugged in to any extension socket must also use a filter.
stewp
Re: Line speed
I meant test socket. Theres only 1 socket in the house.
jim:quote
Fixes: 21
Re: Line speed
When you are connected to the Test socket and up and running can you post the full DSL stats. Assuming it's the 582n, to get the stats, login into your modem/router and under DSL Connection, click View more ..... as shown here and then Details on the top RHS. Just Copy and Paste the information into a post.
stewp
Re: Line speed
without any changes
Uptime: 0 days, 1:36:33
DSL Type: ITU-T G.992.5
Bandwidth (Up/Down) [kbps/kbps]: 443 / 3.515
Data Transferred (Sent/Received) [MB/MB]: 20,80 / 372,85
Output Power (Up/Down) [dBm]: 12,9 / 0,0
Line Attenuation (Up/Down) [dB]: 15,5 / 36,5
SN Margin (Up/Down) [dB]: 23,2 / 6,0
Loss of Framing (Local/Remote): 36 / 0
Loss of Signal (Local/Remote): 4 / 0
Loss of Link (Remote): -
Error Seconds (Local/Remote): 1.677 / 0
FEC Errors (Up/Down): 0 / 0
CRC Errors (Up/Down): 36 / 82
HEC Errors (Up/Down): 14 / 72
Plugging into test socket with no filter (so only bb using telephone cable):
Uptime: 0 days, 0:00:29
Bandwidth (Up/Down) [kbps/kbps]: 443 / 3.547
Data Transferred (Sent/Received) [MB/MB]: 20,86 / 372,95
Line Attenuation (Up/Down) [dB]: 15,7 / 36,5
SN Margin (Up/Down) [dB]: 22,9 / 5,8
Loss of Framing (Local/Remote): 45 / 0
Loss of Signal (Local/Remote): 5 / 0
Error Seconds (Local/Remote): 1.688 / 0
CRC Errors (Up/Down): 0 / 0
HEC Errors (Up/Down): 0 / 0
Plugging into test socket with filter and no phone attached:
Uptime: 0 days, 0:00:35
Bandwidth (Up/Down) [kbps/kbps]: 443 / 3.611
Data Transferred (Sent/Received) [MB/MB]: 20,91 / 373,01
SN Margin (Up/Down) [dB]: 23,5 / 5,6
Loss of Framing (Local/Remote): 54 / 0
Loss of Signal (Local/Remote): 6 / 0
Error Seconds (Local/Remote): 1.700 / 0
Got a Belkin router arriving in a few days that I bought off ebay for cheap. Will post back more results then.
Left the current setup of test socket + filter + no phone for testing
Fixes: 21
Re: Line speed
That's definitely not good. If that line attenuation is right you should be up around 10-11Mbps. The errors don't look at all clever either, especially with the short uptime. Definitely looking like a line or exchange fault. Best to double check with another modem/router. How old is the current one?
stewp
Re: Line speed
I just moved to PlusNet last week, the router is brand new
EDITED (answering question)
Fixes: 21
Re: Line speed
Ah, wasn't sure. If it was faulty, it would be a free replacement. And, by the way, welcome to the forums  Cheesy
