Line speed
- Line speed
Line speed
22-11-2012 2:49 PM
Bt speedtester shows IP Profile 2Mbps Plus Net Showing line speed 1.75 please could you correct
Thanks in anticipation
Message 1 of 3
(601 Views)
2 REPLIES 2
Re: Line speed
22-11-2012 3:01 PM
The IP profile according to a diagnostic test I've just performed is actually 1750kbps, however as your connection looks quite stable at the mo I'll submit an SNR reset which should correct that.
Adam.
Adam.
Message 2 of 3
(313 Views)
Re: Line speed
22-11-2012 3:31 PM
Thank you for you help!
Message 3 of 3
(313 Views)
