Line speed
- Line speed
Line speed
27-04-2013 10:14 PM
In the process of moving home. had my phone line re-enabled and went with PlusNet.
Not in my new property atm so bare with me. Left the modem switched on though etc. The line has never had broadband on it before and the phone line has not been in use for about a year. I had a new faceplate fitted a week ago. The guy who did it said that next-door was connected to my line and they shouldn't be (semi-detached house, one line comes in to my house but he's also connected to the box on the exterior of my house). Not sure if this additional info is any use....
Phone exchange: WHITBURN
Estimated line speed:7Mb (This may vary between 5.5Mb and 12Mb) - Checked on 2013-04-14 11:47:57
Current line speed:3.1 Mb
Seems a little low, any ideas? Thanks for any help
Re: Line speed
27-04-2013 10:40 PM
The reason for asking is that I can't think of any reason why a single wire with 4 or more cores can't feed two properties - one pair to each property - and with a pair of semi detached houses it seems a sensible arrangement
I assume that the external box is a BT properly sealed unit
Re: Line speed
27-04-2013 10:48 PM
Re: Line speed
28-04-2013 12:57 AM
Are there extension sockets?
Re: Line speed
29-04-2013 2:00 PM
We're currently testing your line and we'll update your ticket as soon as we've got the results.
Re: Line speed
29-04-2013 8:05 PM
Thanks all,
Stewp
dick:quote
Re: Line speed
30-04-2013 9:50 AM
Re: Line speed
30-04-2013 10:46 AM
Will test a new microfilter tonight. I don't have a second modem except for a talktalk branded one. Will that work? Will call when it's set up.
Thanks,
Stewp
Edit. Will use the master socket. I am guessing a micro filter is needed in that too
Re: Line speed
30-04-2013 2:22 PM
You really must use the Test Socket for these checks.
Do you have any extension phone sockets? Anything that is plugged in to any extension socket must also use a filter.
Re: Line speed
30-04-2013 2:26 PM
jim:quote
Re: Line speed
30-04-2013 2:39 PM
Re: Line speed
30-04-2013 7:32 PM
Uptime: 0 days, 1:36:33
DSL Type: ITU-T G.992.5
Bandwidth (Up/Down) [kbps/kbps]: 443 / 3.515
Data Transferred (Sent/Received) [MB/MB]: 20,80 / 372,85
Output Power (Up/Down) [dBm]: 12,9 / 0,0
Line Attenuation (Up/Down) [dB]: 15,5 / 36,5
SN Margin (Up/Down) [dB]: 23,2 / 6,0
Loss of Framing (Local/Remote): 36 / 0
Loss of Signal (Local/Remote): 4 / 0
Loss of Link (Remote): -
Error Seconds (Local/Remote): 1.677 / 0
FEC Errors (Up/Down): 0 / 0
CRC Errors (Up/Down): 36 / 82
HEC Errors (Up/Down): 14 / 72
Plugging into test socket with no filter (so only bb using telephone cable):
Uptime: 0 days, 0:00:29
Bandwidth (Up/Down) [kbps/kbps]: 443 / 3.547
Data Transferred (Sent/Received) [MB/MB]: 20,86 / 372,95
Line Attenuation (Up/Down) [dB]: 15,7 / 36,5
SN Margin (Up/Down) [dB]: 22,9 / 5,8
Loss of Framing (Local/Remote): 45 / 0
Loss of Signal (Local/Remote): 5 / 0
Error Seconds (Local/Remote): 1.688 / 0
CRC Errors (Up/Down): 0 / 0
HEC Errors (Up/Down): 0 / 0
Plugging into test socket with filter and no phone attached:
Uptime: 0 days, 0:00:35
Bandwidth (Up/Down) [kbps/kbps]: 443 / 3.611
Data Transferred (Sent/Received) [MB/MB]: 20,91 / 373,01
SN Margin (Up/Down) [dB]: 23,5 / 5,6
Loss of Framing (Local/Remote): 54 / 0
Loss of Signal (Local/Remote): 6 / 0
Error Seconds (Local/Remote): 1.700 / 0
Got a Belkin router arriving in a few days that I bought off ebay for cheap. Will post back more results then.
Left the current setup of test socket + filter + no phone for testing
Re: Line speed
30-04-2013 7:58 PM
Re: Line speed
30-04-2013 8:04 PM
EDITED (answering question)
Re: Line speed
30-04-2013 8:11 PM
