Line speed
SWANECO
Line speed
Hi
Ticket Number
Just had BT Openreach round to sort out noisy line.  First class job on time, polite and professional engineer
They rewired to master socket and line is now silent again.
How long before BB speed returns to normal.
33 REPLIES 33
jelv
Fixes: 10
Re: Line speed
Have your sync speeds returned to normal? It may need an SNR reset if your noise margin has been set high due to the fault.
jelv (a.k.a Spoon Whittler)
Mobile: iD mobile (£4/month)
SWANECO
Re: Line speed
HI  router stats as of now
Technicolor TG582n
admin
Home
Technicolor Gateway
Broadband Connection
DSL Connection
Internet Services
Toolbox
Home Network
Help
Home > Broadband Connection > DSL Connection Overview | Details
Physical Connectivity OK
DSL Connection
Link Information
Uptime: 0 days, 0:23:51
DSL Type: ITU-T G.992.5
Bandwidth (Up/Down) [kbps/kbps]: 447 / 1.149
Data Transferred (Sent/Received) [MB/MB]: 49,66 / 337,56
Output Power (Up/Down) [dBm]: 11,8 / 20,1
Line Attenuation (Up/Down) [dB]: 15,2 / 29,5
SN Margin (Up/Down) [dB]: 22,7 / 27,9
Chipset Vendor ID (Local/Remote): BDCM / TSTC
Loss of Framing (Local/Remote): 99 / 0
Loss of Signal (Local/Remote): 15 / 0
Loss of Link (Remote): -
Error Seconds (Local/Remote): 190 / 10
FEC Errors (Up/Down): 14 / 159
CRC Errors (Up/Down): 0 / 0
HEC Errors (Up/Down): 0 / 0
Pick a task...
See information about my broadband connection(s)
jelv
Fixes: 10
Re: Line speed
Ouch!
Please try ONE full reboot of the router - click the disconnect button before you do so - and then post the stats again.
It's looking like you may have been put on to a banded profile because of the fault: http://www.plus.net/support/broadband/speed_guide/broadband_terminology.shtml#bandedProfiles
adamwalker
Fixes: 221
Re: Line speed
Hi SWANECO,
Looks like need to SNR reset the line, however there's a problem with those at the moment. Our suppliers are looking into that for us so I'll keep a note of your details to make sure we get one submitted as soon as we can.
Adam
 Adam Walker
SWANECO
Re: Line speed
Hi.
I disconnected the router and stats are unchanged.
Technicolor TG582n
admin
Home
Technicolor Gateway
DSL Connection
Internet Services
Toolbox
Home Network
Help
DSL Connection
Link Information
Uptime: 0 days, 0:00:46
Bandwidth (Up/Down) [kbps/kbps]: 446 / 1.149
Data Transferred (Sent/Received) [kB/kB]: 24,68 / 150,77
Output Power (Up/Down) [dBm]: 12,0 / 20,1
SN Margin (Up/Down) [dB]: 24,0 / 27,9
FEC Errors (Up/Down): 0 / 0
Pick a task...
jelv
Fixes: 10
Re: Line speed
That's what I feared - see Adam's reply for what needs to be done. In the meantime keep your line stable - no more reboots etc - it is just possible it will in time sort itself out.
adamwalker
Fixes: 221
Re: Line speed
We've just had the headsup it's been fixed so I've just submitted an SNR reset for you.
Adam
 Adam Walker
SWANECO
Re: Line speed
Hi
Uptime: 1 day, 0:47:22
Data Transferred (Sent/Received) [MB/MB]: 6,92 / 50,03
SN Margin (Up/Down) [dB]: 23,9 / 28,0
FEC Errors (Up/Down): 400 / 7.539
Not much change, I have not messed with anything as requested.
Do I just wait , or do I reboot?
Oldjim
Resting Legend
Fixes: 63
Re: Line speed
Just wait - it hasn't worked
MatthewWheeler
Fixes: 480
Re: Line speed
Hi there
Looks like the previous reset didn't go through
I've just done another which has completed.
Your speeds should improve over the next couple of days
Any further issues please let us know
 Matthew Wheeler
SWANECO
Re: Line speed
HI
This is what I have now
Info Jan 12 10:07:38 xDSL linestate up (ITU-T G.992.5; downstream: 4084 kbit/s, upstream: 444 kbit/s; output Power Down: 20.6 dBm, Up: 12.2 dBm; line Attenuation Down: 32.0 dB, Up: 17.5 dB; snr Margin Down: 6.1 dB, Up: 11.0 dB)
This is what I had
Info Oct 3 09:22:01 xDSL linestate up (ITU-T G.992.5; downstream: 14622 kbit/s, upstream: 447 kbit/s; output Power Down: 21.0 dBm, Up: 12.2 dBm; line Attenuation Down: 30.0 dB, Up: 15.7 dB; snr Margin Down: 3.1 dB, Up: 20.0 dB)
Will I get back anywhere near this?
I think the difference is a bit extreme.
AndyH
Re: Line speed
It looks like the SNR reset hasn't gone through again...
SWANECO
Re: Line speed
Hi
i will keep an eye on it and keep you advised.
What stats should i post by the way?
AndyH
Re: Line speed
Actually, sorry - it looks like it might have gone through. Misread your last post.
What you're posting is fine. If you go to http://speedtest.btwholesale.com/ and run the test, then the Further Diagnostics - what does it say for the IP Profiles?
