Line speed question
- Re: Line speed question
Line speed question
24-02-2012 3:54 PM
Hi all,
Just a quick question really, I've carried out a number of speedtest.net tests and my line currently is getting a ping of 22, download of 1.41Mbps and upload of 0.36Mbps;
Annoyingly I've not long moved from a very rural location to somewhere more built up (I'm now 1.49km from exchange according to samknows.com) and I'm actually getting slower speeds here than my old house! I just went to BT's site http://bit.ly/9IIyzE popped in my phone number and it's giving me estimated speeds between 3 and 8Mb. Would my speeds improve that much simply by moving to BT? It's using the exact same copper to get to my house isn't it? Do PlusNet not allow you to use the maximum speed your line can achieve?
Just for interest here are my router stats;
Uptime: 0 days, 0:24:17
DSL Type: G.992.5 annex A
Maximum Bandwidth (Up/Down) [kbps/kbps]: 1,128 / 11,808
Bandwidth (Up/Down) [kbps/kbps]: 443 / 11,800
Data Transferred (Sent/Received) [MB/MB]: 5.54 / 35.42
Output Power (Up/Down) [dBm]: 12.0 / 20.0
Line Attenuation (Up/Down) [dB]: 16.5 / 33.5
SN Margin (Up/Down) [dB]: 27.0 / 6.0
Loss of Signal (Local/Remote): 3 / 0
Loss of Link (Remote): 0
Error Seconds (Local/Remote): 65,536 / 0
FEC Errors (Up/Down): 0 / 0
CRC Errors (Up/Down): 0 / 86
HEC Errors (Up/Down): 0 / NA
Can anyone see anything wrong with these stats or do they look normal?
Many thanks.
Many thanks.
Message 1 of 7
(1,096 Views)
6 REPLIES 6
24-02-2012 4:10 PM
Hi ch5497,
As your new line has just been enabled its in a 10 day line training period, during which the best speed your line can achieve whilst remaining stable is calculated.
To cut a long story short your line speeds should improve over the next week or so, if they don't I'd urge you to let us know.
Message 2 of 7
(523 Views)
24-02-2012 4:12 PM
Ah, I see. Thanks for the speedy reply.
Message 3 of 7
(523 Views)
24-02-2012 4:40 PM
Message 4 of 7
(523 Views)
02-03-2012 2:31 PM
Message 5 of 7
(523 Views)
02-03-2012 2:33 PM
I've noticed my line is erroring quite a lot, is this normal?
Link Information
Uptime: 1 day, 18:37:09
Maximum Bandwidth (Up/Down) [kbps/kbps]: 1,120 / 11,708
Bandwidth (Up/Down) [kbps/kbps]: 443 / 11,032
Data Transferred (Sent/Received) [MB/MB]: 39.30 / 616.46
SN Margin (Up/Down) [dB]: 26.0 / 7.0
Error Seconds (Local/Remote): 8 / 0
FEC Errors (Up/Down): 21,664 / 0
CRC Errors (Up/Down): 1,281 / 4,516
HEC Errors (Up/Down): 7 / 14,378
Regards,
- Craig.
Link Information
Regards,
- Craig.
Message 6 of 7
(523 Views)
02-03-2012 4:23 PM
Hi Craig,
I have raised your profile to 10200 to allow for your new BT IP profile. This should take effect shortly. Let me know how that goes.
Jojo
Jojo
Message 7 of 7
(523 Views)
