Line speed limited to 40Mbps
- Re: Line speed limited to 40Mbps
26-03-2014 9:36 AM
I'm on fibre broadband, I'm getting strong upload speeds (16.5Mbps). But my download seems to be limited to 40Mbps.
Message 1 of 8
(1,500 Views)
7 REPLIES 7
26-03-2014 9:39 AM
Please provide the information requested http://community.plus.net/forum/index.php/topic,96155.0.html except for router stats
Message 2 of 8
(860 Views)
26-03-2014 10:14 AM
Hi, here it is:
1. Best Effort Test: -provides background information.
Download Speed
36.35 Mbps
0 Mbps 69.72 Mbps
Max Achievable Speed
Download speedachieved during the test was - 36.35 Mbps
For your connection, the acceptable range of speedsis 55.78 Mbps-69.72 Mbps .
Additional Information:
IP Profile for your line is - 69.72 Mbps
Upload Speed
16.51 Mbps
0 Mbps 20 Mbps
Upload speed achieved during the test was - 16.51Mbps
AND
Estimated line speed:
35Mb (Download speed could vary depending on line conditions. Estimates are the maximum speeds that your phone line can support. These speeds are dependent on the package you choose.) - Checked on 2014-03-17 15:39:37
Current line speed:
38.6 Mb
Download Speed
36.35 Mbps
0 Mbps 69.72 Mbps
Upload Speed
16.51 Mbps
0 Mbps 20 Mbps
AND
Current line speed:
38.6 Mb
Message 3 of 8
(860 Views)
26-03-2014 10:25 AM
There is the problem
Current Line Speed needs fixing
It should be picked up here today
Message 4 of 8
(860 Views)
26-03-2014 10:34 AM
Hi londamas,
I've just updated the Speed Profile for you. If you log into your router and hit the 'Disconnect' button and 'Connect' again, that should resolve the issue for you.
Message 5 of 8
(860 Views)
27-03-2014 12:47 PM
Thanks for doing that Chris, there's been a big increase in speed...
Download Speed
59.64 Mbps
0 Mbps 69.51 Mbps
Download speedachieved during the test was - 59.64 Mbps
For your connection, the acceptable range of speedsis 55.61 Mbps-69.51 Mbps .
IP Profile for your line is - 69.51 Mbps
Upload Speed
15.83 Mbps
0 Mbps 20 Mbps
Upload speed achieved during the test was - 15.83Mbps
and
Current line speed:
78 Mb
I'm getting a max of 62.5Mbps on the speedtest, which is so much better than yesterday's 34!
But why is the IP profile (69.51) quite a bit lower than the line speed (78)?
Download Speed
59.64 Mbps
0 Mbps 69.51 Mbps
Upload Speed
15.83 Mbps
0 Mbps 20 Mbps
and
Current line speed:
78 Mb
Message 6 of 8
(860 Views)
27-03-2014 1:02 PM
When changes are made or when you are provisioned you are automatically put on the maximum possible line rate and it will automatically align itself within a couple of days - so it'll sort itself out
Message 7 of 8
(860 Views)
27-03-2014 2:53 PM
Thanks Chris.
Message 8 of 8
(860 Views)
