Line speed has dropped from 6mb to 1mb
- Line speed has dropped from 6mb to 1mb
20-01-2013 7:45 AM
From 10-01-2013 to 17-01-2013 I had a phone line problem, phones not working(broadband still worked) and this was repaired by BT, but since then my line speed has dropped from what was a steady 5mbps to a a slow 1mbps.
DSL Connection
Link Information
Uptime:
0 days, 6:08:31
DSL Type: G.992.1 annex A
Bandwidth (Up/Down) [kbps/kbps]:448 / 5,856
Data Transferred (Sent/Received) [kB/kB]:0.00 / 0.00
Output Power (Up/Down) [dBm]:12.0 / 19.5
Line Attenuation (Up/Down) [dB]:17.0 / 34.0
SN Margin (Up/Down) [dB]:26.0 / 8.5
Vendor ID (Local/Remote):TMMB / IFTN
Loss of Framing (Local/Remote):0 / 0
Loss of Signal (Local/Remote):0 / 0
Loss of Power (Local/Remote):0 / 0
Loss of Link (Remote):0
Error Seconds (Local/Remote):11 / 0
FEC Errors (Up/Down):0 / 1,178,731
CRC Errors (Up/Down):0 / 37
HEC Errors (Up/Down):0 / 31
DSL Connection
Link Information
Uptime:
0 days, 6:08:31
Message 1 of 4
(1,004 Views)
3 REPLIES 3
Re: Line speed has dropped from 6mb to 1mb
20-01-2013 8:18 AM
Your line sync speed, according to the stats in your previous post, is 5856 kbps. It's still not that great, given that your downstream attenuation is 34 dB but perhaps that is because your target SNR has been raised (to 9dB presumably) as a result of your phone line problem. So it would probably be best to report this as a speed fault.
If you are only getting 1Mbps it is probably because your BT IP Profile (run the test here http://speedtest.btwholesale.com/ then choose Further Diagnostics) or your Plusnet Profile (shown here https://portal.plus.net/m...ction=data_transfer_speed as Current Line Speed) has not caught up with your improved sync speed. This will happen in time but if your Current Line Speed is lagging behind your BT IP Profile then Plusnet Tech Support should be able to remedy this for you if you call them.
Message 2 of 4
(515 Views)
20-01-2013 8:32 AM
Cheers for that, I have raised a ticket with support team
Message 3 of 4
(515 Views)
21-01-2013 11:47 AM
We've picked your fault ticket up, I've checked over your line and can see no apparent mismatch anywhere, so we're investigating further.
Also to confirm are you using a wired or wireless connection?
Message 4 of 4
(515 Views)
