Line speed dropped from 74Mb to 2Mb
- Re: Line speed dropped from 74Mb to 2Mb
27-02-2013 9:48 PM
I thought Id noticed my line speed had dropped considerably recently, but hadn't realised it was as bad as its got.
Is this normal after a month to drop from 74Mb to 2Mb? Not exactly what Id signed up for. Can someone look into this for me please?
Message 1 of 7
(1,490 Views)
6 REPLIES 6
27-02-2013 10:14 PM
The same thing happened to me a few weeks back. Very similar down speed and ping numbers!
I connected direct to the BTOR modem and got my normal speeds! So, I did a reset of the router and "Normal Service was Resumed"!
Geoff,
York.
York.
Message 2 of 7
(586 Views)
27-02-2013 11:16 PM
Thanks Geoff
Just tried that. Speed did actually increase slightly but still awful.
I did run the BT self test thing suggested and that comes back showing its not right and "need to contact your ISP".
Message 3 of 7
(586 Views)
28-02-2013 7:22 AM
Look at thisi thread http://community.plus.net/forum/index.php/topic,112521.0.html
Message 4 of 7
(586 Views)
28-02-2013 8:34 PM
i ran the bt test. it said:
Quote No Fibre to the Premises (FTTP) services have been found at this address. Please check the postcode or use the Telephone Number or Service ID to conduct the test.
Message 5 of 7
(586 Views)
28-02-2013 10:39 PM
i rang in the end. There is a line fault.
Message 6 of 7
(586 Views)
28-02-2013 10:44 PM
My impression from your previous posting is your are on FTTC not FTTP so you could have picked the wrong BT test.Try it again, When the first test is complete, press Further Diagnostics, enter only your phone number and run the test.
Message 7 of 7
(586 Views)
