Line speed dropped from 2.5mb to 512k is my cn21 activated?
- Line speed dropped from 2.5mb to 512k is my cn21 a...
24-09-2009 11:20 PM
Re: Line speed dropped from 2.5mb to 512k is my cn21 activated?
24-09-2009 11:35 PM
Today 23:21 526 kbps (65.8kB/s) 125 kbps (15.6kB/s) Share
Today 23:14 542 kbps (67.8kB/s) 218 kbps (27.3kB/s) Share
Tuesday 23:12 2338 kbps (292kB/s) 335 kbps (41.9kB/s) Share
Aug 10, 19:11 2660 kbps (333kB/s) 321 kbps (40.1kB/s) Share
Jul 23, 20:57 2797 kbps (350kB/s) 333 kbps (41.6kB/s) Share
Jul 21, 23:15 2778 kbps (347kB/s) 335 kbps (41.9kB/s) Share
Thomson Gateway Information
Product Name: TG585 v7
Software Release: 7.4.4.7
24-09-2009 11:44 PM
25-09-2009 8:34 AM
It also looks from your sync speed that you've been put on a fixed 512k rather than ADSL2+
25-09-2009 8:38 AM
25-09-2009 8:42 AM
25-09-2009 8:44 AM
25-09-2009 9:14 AM
You are on ADSL2+, but it looks, er, a bit on the slow side.
Can you try rebooting your router and see if it makes any difference at all?
25-09-2009 9:16 AM
25-09-2009 9:19 AM
It sounds like a dodgy resync event which might have resulted in a banded profile. If you still sync at the same speed after a reboot - leave it for 3 days and the sync speed should spring back to life.
25-09-2009 9:21 AM
25-09-2009 9:22 AM
25-09-2009 9:24 AM
It's part of the initial training period, I'd suspect.
25-09-2009 9:26 AM
25-09-2009 9:28 AM
Quote 00:00:45 (since last boot) xDSL linestate up (ITU-T G.992.1; downstream: 576 kbit/s, upstream: 288 kbit/s
@Jameseh
The router stats suggest that the router is connecting using standard DSL (ITU-T G992.1 is standard ADSL) and the sync rates are those of a fixed 512k service (576down 288up). Has his equipment negotiated a standard ADSL connection with the exchange or is there something else up?
