Line speed curiosity
njay
Ok. This is really for my own curiosity as I hopefully will be upgraded to fibre tomorrow (Router turned up yesterday so all set. Still have the original Thomson 585v7 sent to me when I upgraded to adsl2 3 years ago Smiley)
Anyway. I have always wondered if I am getting as good as I should so can someone comment on my scores on the doors which I have just harvested for posterity before tomorrow Smiley
I am about 3.5miles from the exchange if that helps.
Tp-link 8960n
Statistics -- xDSL
Mode: ADSL_2plus
Traffic Type: ATM
Status: Up
Link Power State: L0
Downstream Upstream
Line Coding(Trellis): On On
SNR Margin (0.1 dB): 73 53
Attenuation (0.1 dB): 600 347
Output Power (0.1 dBm): 0 128
Attainable Rate (Kbps): 4304 980
Path 0 Path 1
Downstream Upstream Downstream Upstream
Rate (Kbps): 3542 980 0 0
MSGc (# of bytes in overhead channel message): 59 51 0 0
B (# of bytes in Mux Data Frame): 110 38 0 0
M (# of Mux Data Frames in FEC Data Frame): 2 4 0 0
T (Mux Data Frames over sync bytes): 1 1 0 0
R (# of check bytes in FEC Data Frame): 16 4 0 0
S (ratio of FEC over PMD Data Frame length): 1.9874 4.9612 0.0 0.0
L (# of bits in PMD Data Frame): 958 258 0 0
D (interleaver depth): 16 4 0 0
Delay (msec): 7.94 4.96 0.0 0.0
INP (DMT symbol): 1.6 0.24 0.0 0.0
Super Frames: 11349182 876588 0 0
Super Frame Errors: 0 0 0 0
RS Words: 368848424 1681193 0 0
RS Correctable Errors: 8812784 0 0 0
RS Uncorrectable Errors: 113144 0 0 0
HEC Errors: 0 5376 0 0
OCD Errors: 464 0 0 0
LCD Errors: 2 0 0 0
Total Cells: 1530770335 1819825 0 0
Data Cells: 35066993 9084 0 0
Bit Errors: 0 0 0 0
Total ES: 1364 0
Total SES: 87 0
Total UAS: 32 4294967113
1 REPLY
Fixes: 25
Re: Line speed curiosity
I would say that given your 60dB of downstream attenuation your download speed is (was) very good indeed.
