Line slowdown every night
- Line slowdown every night
21-07-2016 9:10 PM
After roughly 5pm, my adsl connection slows down a ton. My ping in games then varies from around 20 to 10,000ms which is unplayable to say the least. WiFi shouldnt be to blame as it is fine at all other times of the day. and i'm also the only other user on channel 1 in my area. No other users are using the internet on their devices usually at this time, i often check to see if that is whats causing the lag (often is but not this time) What causes this slowdown? And if it's other people in the area, why is the infrastructure so bad?
Ping is in bottom left of sc to prove my point
Re: Line slowdown every night
21-07-2016 9:51 PM - edited 21-07-2016 9:55 PM
What does that ^ show if you run it for a while? e.g.
ping 192.168.1.254 -t
Pinging 192.168.1.254 with 32 bytes of data:
Reply from 192.168.1.254: bytes=32 time=3ms TTL=64
Reply from 192.168.1.254: bytes=32 time=5ms TTL=64
Reply from 192.168.1.254: bytes=32 time=4ms TTL=64
^C
22-07-2016 1:31 PM
I'll run that later on today, when the problem arises.
22-07-2016 6:41 PM
Reply from 192.168.1.254: bytes=32 time=2ms TTL=64
Reply from 192.168.1.254: bytes=32 time=1ms TTL=64
Reply from 192.168.1.254: bytes=32 time=7ms TTL=64
Reply from 192.168.1.254: bytes=32 time=6ms TTL=64
Reply from 192.168.1.254: bytes=32 time=14ms TTL=64
Reply from 192.168.1.254: bytes=32 time=15ms TTL=64
Ping statistics for 192.168.1.254:
Packets: Sent = 43, Received = 43, Lost = 0 (0% loss),
Approximate round trip times in milli-seconds:
Minimum = 1ms, Maximum = 15ms, Average = 3ms
Control-C
^C
Problem hasn't occurred much tonight, but every now and then it slows down. So when i noticed slowdown i ran it.
22-07-2016 8:50 PM
Had a bigger issue now, 2000 ping in counter strike. Ran it again and got this:
Reply from 192.168.1.254: bytes=32 time=1822ms TTL=64
Reply from 192.168.1.254: bytes=32 time=1075ms TTL=64
Reply from 192.168.1.254: bytes=32 time=102ms TTL=64
Reply from 192.168.1.254: bytes=32 time=46ms TTL=64
Reply from 192.168.1.254: bytes=32 time=176ms TTL=64
Reply from 192.168.1.254: bytes=32 time=26ms TTL=64
Reply from 192.168.1.254: bytes=32 time=11ms TTL=64
Reply from 192.168.1.254: bytes=32 time=61ms TTL=64
Reply from 192.168.1.254: bytes=32 time=19ms TTL=64
Reply from 192.168.1.254: bytes=32 time=18ms TTL=64
Packets: Sent = 26, Received = 26, Lost = 0 (0% loss),
Minimum = 2ms, Maximum = 1822ms, Average = 131ms
Control-C
^C
