Line reset
- Line reset
Line reset
22-08-2016 8:38 AM
Hi is it possible to do a reset on my line it seems to have returned to a reasonably stable connection ( I hope ) cheers
Re: Line reset
22-08-2016 7:38 PM
Re: Line reset
22-08-2016 8:21 PM
will do cheers
Re: Line reset
22-08-2016 10:38 PM
I still don't understand why I have to reboot the router to get the new settings ? ? this was never needed with my last provider and IP profile increases automatically kicked in but not with Plusnet why is that ?
Re: Line reset
23-08-2016 1:49 PM - edited 23-08-2016 1:50 PM
did a re-sync but this can't be right
Re: Line reset
23-08-2016 1:57 PM
Re: Line reset
23-08-2016 2:32 PM
wired
Re: Line reset
23-08-2016 2:34 PM
wondering if I should re-sync again ?
Re: Line reset
23-08-2016 2:37 PM
Re: Line reset
23-08-2016 2:59 PM - edited 23-08-2016 3:00 PM
not sure what you mean by that sorry
Re: Line reset
23-08-2016 3:02 PM
if you mean disconnecting ethernet then yes tried it same speed by wireless too
Re: Line reset
23-08-2016 6:27 PM
looking at system log looks like a admin disconnect from the exchange end but what ever it was it seems to have cured the download speed so here's hoping it stays stable cheers
Re: Line reset
24-08-2016 1:12 PM
