Line reset please?
Mikejstephens
Line reset please?
Following 2 days of noisy line (historic fault on D side - never fixed after 14 engineer visits!) Noise gone for now.  Speed has dropped to 2.39 although profile is still 3.75.  Exchange has not rectified this so could you do a reset please.
Many thanks.  Mike
Plusnet Staff
Plusnet Staff
Fixes: 5
Re: Line reset please?
Hi Mike,
I've just put the reset through for you - please allow up to 4 hours for the changes to take effect.
Chris Pettitt
Cloud Environments Engineer
Mikejstephens
Many thanks - yet again!!
Mikejstephens
Still no change at 8am Tuesday?  BT Speedtester attached
I've updated your speed profile to as that was not aligned correctly, you should hopefully see the difference in 15 minutes or so.
Mikejstephens
Thanks Chris - all fine - until the next time!  Great service, much appreciated.  Cheers, Mike
