Line reset please
kyle36
Line reset please
Would it be possible to have my broadband line reset as I have installed a new  faceplate and believe that i can sync at a higher rate than my line was capable of before.
Regards
Kyle36
Plusnet Staff
Plusnet Staff
Fixes: 5
Re: Line reset please
Hi Kyle36,
That's been submitted for you. You should notice a change within the next half an hour or so.
Chris Pettitt
Cloud Environments Engineer
kyle36
Thanks for your help chris much appreciated.
regards
kyle36
