Line reset please?
- Re: Line reset please?
Line reset please?
14-04-2014 8:08 AM
Following 2 days of noisy line (historic fault on D side - never fixed after 14 engineer visits!) Noise gone for now. Speed has dropped to 2.39 although profile is still 3.75. Exchange has not rectified this so could you do a reset please.
Many thanks. Mike
Many thanks. Mike
Message 1 of 6
(751 Views)
5 REPLIES 5
14-04-2014 11:13 AM
Hi Mike,
I've just put the reset through for you - please allow up to 4 hours for the changes to take effect.
Message 2 of 6
(428 Views)
14-04-2014 11:59 AM
Many thanks - yet again!!
Message 3 of 6
(428 Views)
15-04-2014 8:14 AM
Still no change at 8am Tuesday? BT Speedtester attached
Message 4 of 6
(428 Views)
15-04-2014 8:23 AM
I've updated your speed profile to as that was not aligned correctly, you should hopefully see the difference in 15 minutes or so.
Message 5 of 6
(428 Views)
15-04-2014 12:58 PM
Thanks Chris - all fine - until the next time! Great service, much appreciated. Cheers, Mike
Message 6 of 6
(428 Views)
