Line rental and calls only moving from BT to PO. Will my Plusnet broadband remain untouched?
- Re: Line rental and calls only moving from BT to P...
25-08-2017 12:00 PM
I currently have line rental and phone calls with BT, and Fibre (FTTC) broadband from Plusnet.
I am switching to the Post Office for line rental and calls. The Post Office say my Plusnet broadband will be unaffected by the switch. Are they correct?
I have heard of instances of BT doing a full cease and reprovide when switching away (or even doing a name change).
Re: Line rental and calls only moving from BT to PO. Will my Plusnet broadband remain untouched?
25-08-2017 2:07 PM
28-08-2017 1:55 PM
28-08-2017 2:21 PM
Regardless as to what BT do the Post Office could screw it up as they provided Broadband over TalkTalk LLU and if they move you to their LLU phone provide it will screw it up
Given that you intend to keep the phone separate why don't you consider Pulse8 which is much cheaper and they don't normally screw it up
28-08-2017 5:30 PM
Pulse8 looks attractive for line rental and calls. I've not come across them before.
Post Office have told BT they are taking over the line rental and calls. I have told Post Office there is Plusnet broadband on the line and I wan to keep it and they said it will be OK. But, I have experience of BT...
30-08-2017 10:26 AM
I agree with Oldjim
If the Post Office use LLU equipment in your exchange then when the phone service migrates away it's very likely the broadband service will cease. Let us know how you get on with the migration.
31-08-2017 10:57 AM
Just double checked with post office. They say that I can have PO homephone (rental and calls only) and keep Plusnet broadband. When they take over from BT, they will not switch to their LLU equipment because only the line and calls are moving (not the broadband).
They also said if the line, calls and broadband were moving they would switch to LLU.
31-08-2017 12:01 PM
That's good to hear.
I'm sure you have your own reasons but may I ask if you've considered moving your phone service to Plusnet? We'd be able to provide you with a cheaper deal on your broadband service.
31-08-2017 12:30 PM
I did look at using Plusnet but the PO deal appears to be cheaper (at least in the first year), off peak starts at 6pm and free caller ID. Not fussed about call packages. We use mobiles and VOIP to make calls. The odd time we use the landline outside any free call period, we use 18185.
31-08-2017 2:53 PM
If you don't use the landline for outgoing calls £13 per month (inc. VAT) is what you should be paying for line rental.
31-08-2017 3:25 PM - edited 31-08-2017 3:26 PM
It rather depends as once you include Caller Display the saving is only £1 and that isn't many calls on evenings and weekends - that is assuming that you actually need that for the phone
31-08-2017 5:18 PM
I am currently on unlimited fibre extra at 22.49 a month
If I switched line rental to plusnet this would rise to 29.99 a month (is that correct it isn't 100% clear).
That would be pay as you go line rental. To add weekend calls (& evenings) is another £4 a month from what I can make out with off peak starting at 7pm. Can't see how much Caller ID display would be and 18185 would be blocked (ok there is an 080xxxx work around).
PO homephone is £15 a month (12 month contract) includes weekend calls (6pm Fri to 6am Mon), caller ID display and can use 18185. Also free calls to other PO numbers at anytime. And a £20 welcome bonus for being referred by a friend.
It's close.
31-08-2017 5:50 PM
If you move your phone service to Plusnet, your broadband will be £2.50 cheaper, so £19.99 + line rental £18.99 + any call packages you choose to add. Caller Display is 99 pence per month.
31-08-2017 5:50 PM
08-09-2017 11:10 AM
Switch to Post Office Homephone is today.
