Line quality reviews
goldenfibre
My ADSL2+ with sync rate of 16870K with IP Profile 13000K for 22 hours so far look very healthy line. Does this reviews look good ? below with three snapshots here: Look like 2 more days before the profile will rise to 14000K and that is the final maximum speed on my line can get. Smiley
goldenfibre
Re: Line quality reviews
Jojo, can you please sent me a connection log with my line delta report eg: bras report, errors count on the line and so on. So far, I had stable for 2 days and 16 hours. The profile should rise to 14000K anytime today with the excellent line sync of 16870K. Thanks
jojopillo
Hi goldenadsl,
I can give you the connection log (below) but as for the other figures, I can only get them with more intrusive tests which can be time consuming and would normally only be done as part of a fault investigation. Just remember, that you're waiting for your profile to uplift by 1000k and as this is less than an 8% increase it can take up to 120 hours.
Jojo Smiley
goldenfibre
Thanks jojo for the log, before I was at 12000K and after 75 hours the profile had rise to 13000K. I believe it will do the same from 13000K to 14000K in 75 hours again unless a new 88.2% profile will kick in at anytime now until 10th October. But, I won't hold my hope up cos I don't think BT won't do it at my exchange and probably staying at old profile for years to come. Hope BT proved me wrong.
Jojo if my line was sync at 16870K, IP Profile of 14000K, what is the profile rate after 88.2% kick in ? Is it from 14000K to 15873K ? Am I right ?
jojopillo
My calculations would make it 14879
goldenfibre
Thanks jojo, that a massive huge difference, will plusnet move me to 15000K from the BT end 14879K to nearer round it. Hope my exchange get 88.2% on Monday. Smiley
