Line move payment..
- Line move payment..
- « Previous
- 1
- 2
- Next »
Re: Line move payment..
20-11-2007 4:01 PM
Fingers crossed
Message 16 of 20
(335 Views)
28-11-2007 12:22 PM
Okies, I will post a reply to the ticket in a moment, but first..
Can someone give my configured rate a kick please?
<rubbish java test>
Test1 comprises of Best Effort Test: -provides background information.
IP profile for your line is - 2000 kbps
DSL connection rate: 832 kbps(UP-STREAM) 8128 kbps(DOWN-STREAM)
Actual IP throughput achieved during the test was - 1873 kbps
If you wish to discuss these results please contact your ISP.
If you are experiencing problems with specific applications, servers or websites please contact your ISP for assistance.
Your test has completed please close this window to exit the performance tester.
</rubbish java test>
And router stats
Status
Configured Current
Line Status --- SHOWTIME
Link Type --- Interleaved Path
Data Rate
Stream Type Actual Data Rate
Up Stream 832 (Kbps.)
Down Stream 8128 (Kbps.)
Operation Data
Operation Data Upstream Downstream
Noise Margin 14 dB 13 dB
Attenuation 28 dB 25 dB
Defect Indication
Indicator Name Near End Indicator Far End Indicator
Fast Path FEC Correction 0 0
Interleaved Path FEC Correction 0 0
Fast Path CRC Error 0 0
Interleaved Path CRC Error 0 0
Loss of Signal Defect 0 ---
Fast Path HEC Error 0 0
Interleaved Path HEC Error 0 0
Statistics
Received Cells 828088
Transmitted Cells 86154
Ta muchly
<rubbish java test>
And router stats
Status
Configured Current
Data Rate
Operation Data
Defect Indication
Statistics
Ta muchly
Message 17 of 20
(335 Views)
28-11-2007 12:24 PM
McGurka,
That's the BT Profile rather than the PlusNet one. You can tell that from the "IP Profile" being set at 2000Kbps.
Give it a day or so and it should increase.
Message 18 of 20
(335 Views)
28-11-2007 12:25 PM
Thank you, PN's is sitting at 5500 but im assuming that will go up in line with BT's.
Give chris my thanks!
Scott
Scott
Message 19 of 20
(335 Views)
28-11-2007 12:26 PM
Good to know it's gone ok this time
Message 20 of 20
(335 Views)
- « Previous
- 1
- 2
- Next »
