Line installation chaos
- Line installation chaos
Re: Line installation chaos
30-01-2015 11:12 AM
There is a box on the pole at the end of our drive but I couldn't tell you if this is new or not. It's quite possible that it went in when we were at work.
While it does seem odd that BT would install a line that cannot be used with broadband it would not be overly surprising given everything I've learnt about how Openreach operate.
Tony, can you give me an update as to what has happened as soon as you know? I could ring the support line but I always seem to get the same answer.
30-01-2015 5:00 PM
30-01-2015 5:16 PM
I can't see anything other than a telephone socket in the wall. I don't know if the line is active as I don't have a phone to plug in to it. I've no need for a house phone, just the broadband!
What can I check for? Shall I plug the router in?
30-01-2015 5:33 PM
30-01-2015 5:40 PM
I take your point, very sensible.
03-02-2015 4:52 PM
I received an email on Saturday that said our broadband would be enabled on Saturday 7th Feb.
I have also just had a reply to my emailed complaint (sent on 27th January) that the broadband order is delayed again.
Please can you check this and provide me with an update? Conflicting reports are rather par for the course with this order.
05-02-2015 1:29 PM
Could you look at this please Tony?
05-02-2015 6:43 PM
I've checked BT systems which I admit are rather confusing. The contractual date (the actual date of activation) is still set for tomorrow. Unfortunately, their is an error showing a delay. I'm going to try to get some further information on this from BT for you now.
05-02-2015 7:03 PM
I'm not in the office, but I'm sure a colleague will get this picked up for you.
05-02-2015 7:17 PM
05-02-2015 7:24 PM
06-02-2015 10:13 AM
I've e-chatted our suppliers today regarding getting you connected, they have advised that work needs to be done on the line to get the DACS system removed. We're hoping to have a further update for you on Monday. I'm really sorry I can't give you any further information today.
06-02-2015 7:11 PM
The BT engineer told me he was installing a DACS phone line that didn't allow for broadband.
BT then told Plusnet that this wasn't the case.
Now BT are saying that the order is being delayed again to remove the DACS line that they did or didn't install depending on who you believe?
This is completely absurd.
Please can someone explain to me what Plusnet are doing to get this solved? I understand that BT are doing the work but nobody from Plusnet seems to be doing anything unless I complain.
06-02-2015 7:51 PM
09-02-2015 11:28 AM
Sadly I paid for the line rental upfront to save a bit of money so Plusnet have already had over £200 from me. If I was able to get this back from them I would!
It's worth mentioning that last night I had to top up my 3G MiFi unit for a third month. Based on my usage this is costing me £20 per month.
I'm very tolerant (perhaps too tolerant) and understand that some things take time, that a new line won't be installed within a week, but given we are approaching the four month anniversary I will be requesting some of this money back from Plusnet when everything is solved.
