Line fault or DLM ?(inc HG612 router stats)
ajmalsheikh
Hi, Having been on fibre for about 4 months can someone look at my stats and see if DLM will ever  increase the speed back. Since a powercut a couple of months back DLM put interleaving on and cut the speed by around 10meg on the download. my profile went from 78 to the current 68 bras i believe. I have trolled how to cut the potential errors and possible interference and purchased the tandy 0.5m twisted cat5e modem cable and changed my adslnation faceplace to an offical bt mk2 one, (the fibre engineer never changed it at install) and updated hg612 firrmware to the latest one.
sorry for the long post with all the HG612 stats
the max down rate originally was around 96000, and the line was synced at 80/20 for before the powercut.
Stats On March 23rd 2014:
Max: Upstream rate = 38700 Kbps, Downstream rate = 92668 Kbps
Path: 0, Upstream rate = 19999 Kbps, Downstream rate = 79999 Kbps
Link Power State: L0
Mode: VDSL2 Annex B
VDSL2 Profile: Profile 17a
TPS-TC: PTM Mode
Trellis: U:ON /D:ON
Line Status: No Defect
Training Status: Showtime
Down Up
SNR (dB): 9.5 23.4
Attn(dB): 0.0 0.0
Pwr(dBm): 13.5 6.6
VDSL2 framing
Path 0
B: 239 237
M: 1 1
T: 23 42
R: 0 16
S: 0.0955 0.3781
L: 20107 5374
D: 1 1
I: 240 127
N: 240 254
Counters
Path 0
OHF: 196725142 1649417
OHFErr: 1636 123
RS:         0 894542
RSCorr: 0 72
RSUnCorr: 0 0
Path 0
HEC: 2515 0
OCD: 0 0
LCD: 0 0
Total Cells: 2779687183 0
Data Cells: 1072877605 0
Drop Cells: 0
Bit Errors: 0 0
ES:       485 117
SES: 0 0
UAS: 19 19
AS:         325315
Path 0
INP: 0.00 0.00
PER: 1.64 3.97
delay: 0.00 0.00
OR: 116.56 64.47
Bitswap: 7458 436
Since Link time = 3 days 18 hours 21 min 53 sec
FEC: 0 72
CRC: 1636 123
ES:         485 117
SES: 0 0
UAS: 0 0
LOS: 0 0
LOF: 0 0
current stats are:
Max: Upstream rate = 31517 Kbps, Downstream rate = 79336 Kbps
Bearer: 0, Upstream rate = 19999 Kbps, Downstream rate = 68767 Kbps
Mode: VDSL2 Annex B
TPS-TC: PTM Mode(0x0)
Trellis: U:ON /D:ON
Down Up
SNR (dB): 6.1 15.7
Attn(dB): 15.9 0.0
Pwr(dBm): 13.5 6.8
VDSL2 framing
Bearer 0
MSGc: 18 26
B: 51 237
M: 1 1
T: 64 42
R: 12 16
S: 0.0241 0.3781
L: 21280 5374
D: 1345 1
I: 64 127
N: 64 254
Counters
Bearer 0
OHF: 182229401 3344045
OHFErr: 46 165
RS:       3700889545 3485737
RSCorr: 516105 152
RSUnCorr: 528 0
Bearer 0
HEC: 81 0
OCD: 3 0
LCD: 3 0
Total Cells: 2890490881 0
Data Cells: 601644517 0
Drop Cells: 0
Bit Errors: 0 0
ES: 6 151
SES: 0 0
UAS: 23 23
AS: 281709
Bearer 0
INP: 3.00 0.00
INPRein: 0.00 0.00
delay: 8 0
PER: 1.54 3.98
OR: 124.20 64.22
AgR: 68890.89 20063.54
Bitswap: 76974/76974 387/387
Since Link time = 3 days 6 hours 15 min 7 sec
FEC: 516105 152
CRC: 46 165
ES:         6 151
SES: 0 0
UAS: 0 0
LOS: 0 0
LOF: 0 0
LOM: 0 0
I`m wondering if something has caused an error on my line, interleaving still on and not sure what RS and OHF are. FEC has gone up and CRC and ES`s have gone down on the download.
Syncing 10meg under the max rate looks suspicious to me, are overheads that large?
Any thoughts or advice would be appreciated.
Thankyou, Ajmal
Plusnet username: ajmalhome
Fixes: 65
Re: Line fault or DLM ?(inc HG612 router stats)
Hi ajmalhome,
I've just made some checks for you including a line test which didn't flag up any obvious problems.
If there has been somekind of line fault that's since cleared itself DLM hopefully lead to some increase within a few days.
I'd urge you to let us know if this continues to be a downward trend though.
 Adam Walker
Plusnet Staff
Plusnet Staff
Fixes: 5
Hi ajmalhome,
Just to add to Adam's comments;
I've just taken a look at your line and have attached the stats to this post. I've run a separate tests on the Copper side of things which has passed without any problems so don't worry about the voice side of things. The one thing we can't see unfortunately, is, how far you are along on the Caution Counter (explained here: http://community.plus.net/library/browsing/fttc-dlm-what-it-is-how-it-works/ ). From experience, it can take quite a long time for speeds to be restored (longer than we'd all like - something Openreach are aware of are looking into).
With regards to Interleaving, that will likely get switched off once your sync rate returns back to normal, but DLM will decide when this is and as I say, I can't tell how long that is or if your line errors during other parts of the day.
Chris Pettitt
Cloud Environments Engineer
