Line changed to ADSL2 - how do these router stats look??
- Line changed to ADSL2 - how do these router stats ...
15-05-2012 3:47 PM
Line Mode ADSL2 Line State Show Time
Line Power State L0 Line Up Time 00:04:02:08
Line Coding Trellis On Line Up Count 21
Statistics Downstream Upstream
Line Rate 1472 Kbps 656 Kbps
Noise Margin 8.4 dB 5.6 dB
Line Attenuation 64.0 dB 38.8 dB
Output Power 0.0 dBm 12.9 dBm
Any comments, do these look "normal" cheers, Ian
Re: Line changed to ADSL2 - how do these router stats look??
15-05-2012 4:14 PM
15-05-2012 4:30 PM
You may want to consider capping the Upstream to 448 if you don't need the upload speed as some users have reported instability with an uncapped upstream.
If you need to Resync, Reboot, swap anything about that involves loss of sync, stick to doing it in daytime for the moment and whenever, always use the following procedure - Login to the modem/router interface, Disconnect the Internet "ppp" session - wait until it shows Disconnected and then power down the modem/router - wait about a minute before disconnecting from the Line. Wait for about at least 10 minutes before connecting to the line and powering up again, swapping anything you want to in the interval.
(If you want to change modem/router settings, do so whilst it is disconnected from the line).
15-05-2012 7:39 PM
My PN profile indicates 0.5M but my router stats and BT speed test results (current) don't seem to match.
ROUTER STATS AT 19:25
Line Power State L0 Line Up Time 00:00:05:22
Line Coding Trellis On Line Up Count 24
Line Rate 1520 Kbps 648 Kbps
Noise Margin 6.3 dB 6.2 dB
Line Attenuation 65.5 dB 38.7 dB
Output Power 0.0 dBm 12.8 dBm
MSGC (number in overhead channel data) 11 12
B (number of bytes in Mux Frame) 190 40
M (number of Mux Frames in FEC Frame) 1 2
T (Mux Frames over sync bytes) 1 2
R (number of check bytes in FEC Frame) 16 12
S (ratio of FEC over PMD Frame length) 4.0000 4.0000
L (number of bits in PMD Frame) 414 188
D (interleaver depth) 8 8
Delay 8 msec 8 msec
Super Frames 18938 18936
Super Frame Errors 7 42
RS Words 321950 643824
RS Correctable Errors 865 89
RS Uncorrectable Errors 41 0
HEC Errors 7 0
OCD Errors 0 0
LCD Errors 0 0
ES Errors 0 0
RESULTS OF BT SPEEDTEST
1. Best Effort Test: -provides background information.
Download Speed
0.43 Mbps
0 Mbps 2 Mbps
Max Achievable Speed
Download speedachieved during the test was - 0.43 Mbps
For your connection, the acceptable range of speeds is 0.8 Mbps-2 Mbps.
IP Profile for your line is - 1.34 Mbps
Upload Speed
0.55 Mbps
0 Mbps 0.83 Mbps
Upload speed achieved during the test was - 0.55Mbps
Additional Information:
Upstream Rate IP profile on your line is - 0.83 Mbps
I'm supposed to be getting a visit from a BT engineer on Monday (21/05) to check the line so I am keen to eliminate everything else.
I am connected direct to the rear of the master socket, new adsl filter fitted , another router on its way but not arrived yet.
Any thoughts, Ian
15-05-2012 8:04 PM
Your Current Line speed at the member centre needs upping to match the BT one - that will sort out your very low speed. I notice Kelly is on-line, whether he's willing/able to adjust it I'm not sure.
Your Target SNRM looks to be 6dB still, so that OK.
15-05-2012 8:21 PM
thanks for comments.
When I first lift the handset there is a little crackling, but not during the call if you understand me.
I am not exactly sure what BT engineer coming for, I had assumed it was to sort out the BB fault.
Still on-line at the moment
Ian
15-05-2012 8:24 PM
15-05-2012 8:32 PM
*crosses fingers*
Ex-Broadband Service Manager
15-05-2012 8:44 PM
15-05-2012 9:05 PM
seems to have improved things judging by BT SPEEDTEST :-
Download Speed
1.22 Mbps
0 Mbps 2 Mbps
Download speedachieved during the test was - 1.22 Mbps
Upload Speed
0.56 Mbps
0 Mbps 0.83 Mbps
Upload speed achieved during the test was - 0.56Mbps
@Anotherone, yes BB and phone from PN. Modem adjusted by disconnect - connect
Lets see what tomorrow brings
Ian
