Line bouncing for no reason
SteveA
There I was working away from home when my VPN dropped out. Router had dropped the line and it didn't want to come back so I rebooted it and it then about 90 minutes later it went bonkers.Nothing changed at my end so all I can assume is BT were messing around in the cabinet.
2024-01-26 12:45:28 [5] System: DSL Link Up us/ds 8329/49242 kbps Type PTM
2024-01-26 14:16:24 [5] System: DSL Link Down
2024-01-26 14:17:44 [5] System: DSL Link Up us/ds 8472/25611 kbps Type PTM
2024-01-26 14:18:11 [5] System: DSL Link Down
2024-01-26 14:18:36 [5] System: DSL Link Up us/ds 996/38300 kbps Type PTM
2024-01-26 14:30:14 [5] System: DSL Link Down
2024-01-26 14:30:39 [5] System: DSL Link Up us/ds 8448/10242 kbps Type PTM
2024-01-26 14:31:58 [5] System: DSL Link Down
2024-01-26 14:32:24 [5] System: DSL Link Up us/ds 8337/52956 kbps Type PTM
Its been stable since.
3 REPLIES 3
Fixes: 253
Re: Line bouncing for no reason
Or you have (intermittent) noise / interference on the circuit.
Straight forward disconnect / reconnect (at the same speed) might reasonably be expected from connections being disturbed in the cabinet, but your reconnection speeds are all over the place, the final being nearly 8% better that the first.
What do the SNRM figures look like for those reconnections?
Fixes: 392
@Ariee43  - As has been said by @Townman above
DS
Seasoned Champion
Fixes: 22
At possible attempt to circumvent restrictions for new forum members/users/abusers and their ability to unlock additional features
I'll leave that and it there.
