Line and broadband down
- Line and broadband down
07-04-2020 11:21 AM
What does someone do when your line and broadband go down and customer support cuts you every time off because of high volume of calls?
Is there another means to register your fault?
Message 1 of 5
(457 Views)
4 REPLIES 4
Re: Line and broadband down
07-04-2020 11:29 AM
I'm having the same issue.
Message 2 of 5
(447 Views)
07-04-2020 11:39 AM
I was on my computer and it just went down around 10ish. I’m in Huddersfield.
Message 3 of 5
(440 Views)
07-04-2020 12:17 PM
They had put a block on my account and disconnected me
Message 4 of 5
(422 Views)
07-04-2020 12:35 PM
I checked my account. Looks ok.
Update: my line was down so I went through the process of going through their troubleshooter for landline. Eventually it gives an option to check the line. The line check came back as an external and fault and it says the fault has now been logged and will take 1-3 days to fix.
So there is a way to log a fault. But you have to follow all the troubleshooter guides.
I hope this helps anyone else who experiences the same problem with their line.
Stay safe. Stay indoors
Message 5 of 5
(411 Views)
