Line Speed slower than expected
- Line Speed slower than expected
- « Previous
- 1
- 2
- Next »
Re: Line Speed slower than expected
05-05-2009 3:55 PM
Also I have another socket upstairs which is coming from the main socket downstairs. Could this cause noise? Or did I bypass this anyway by connecteing to the test socket underneath the face plate?
edit: Yes jelv it was only connected for 16 mins. I will leave it connected for a day and post up the results.
Thanks for the help!
05-05-2009 3:57 PM
When you use the test socket inside the master you should find that all other sockets are dead - if they are not you have a problem.
06-05-2009 1:51 PM
Link Information
Uptime: 0 days, 20:55:40
DSL Type: G.992.1 annex A
Bandwidth (Up/Down) [kbps/kbps]: 448 / 1,920
Output Power (Up/Down) [dBm]: 12.0 / 17.5
Line Attenuation (Up/Down) [dB]: 31.5 / 60.0
SN Margin (Up/Down) [dB]: 16.0 / 16.5
Vendor ID (Local/Remote): TMMB / TSTC
Loss of Link (Remote): 0
FEC Errors (Up/Down): 21 / 8,752
CRC Errors (Up/Down): 21 / 61
HEC Errors (Up/Down): 9 / 45
The throughput speed went up to 1.41 Mbps today even though my IP Profile is 1 Mbps ?? Dont understand that one! But at least its speeding up!
If we can manage to get it up to 2 Mbps I will be happy and leave you all alone
06-05-2009 2:00 PM
06-05-2009 2:36 PM
Is there any noise on your line when you use the phone (you can test by dialling 17070 and use option 2)?
06-05-2009 3:10 PM
06-05-2009 3:17 PM
Have you got a spare filter you could try to see if that changes things - filters do go wrong occasionally, and some are better than others.
07-05-2009 9:10 AM
07-05-2009 9:14 AM
3Mb FTTC
07-05-2009 9:18 AM
Quote from: dtrumble
You are on a very long line, much more than the 1.7miles as the crow flies between you and the exchange!
I am on a 55dB line and 3 miles from the exchange following the road to my house, I have been up at 3Mb or more for many months, over time this is degrading, I am now less than 2Mb. The factors in that degradation could be many. You need to get above 2272kb/s for a 2Mb connection, you may get it for a short time period, but do not expect it to last.
SW.
3Mb FTTC
07-05-2009 10:15 AM
There are few definitive guides on the number of errors, but I don't think I'd bat much of an eyelid at the Downstream errors, although the numbers aren't high it is the Upstream errors that seem a bit high.
When you listen to/use your phone have you heard any cracling or other intermittent noises on the line previously and if so was this repaired or did it just seem to go away?
If you've not got any noise/crackles (the noise you mentioned earlier ..if a very gentle quiet shhhh that's fine), I'd try a filter change first as has been suggested. Make sure it is a quality filter (especially important on a long line) meeting BT spec sin346. Those that look like double adapters are generally lower quality than the "rat's-tail" type.
Also, your extension wiring may add interference. Only the wires to terminals 2 & 5 on the rear of the removeable faceplate should be connected in a broadband situation, same at the extension socket. Remove any orange wires on terminals 3 & 4 by gently pulling them vertically out of the IDC connectors, coil them up neatly and tuck them back out of the way.
Post your latest stats when you've swapped filters.
07-05-2009 12:14 PM
Quote from: dtrumble Hi, Im new to Plusnet just switched over from Tiscali a few days ago.
do you have the router stats you can post here from when you were connected to Tiscali ... it is good for us to make a comparison.
SW.
3Mb FTTC
07-05-2009 5:58 PM
I have Excelsus Z-350UK filters and Excelsus Z-420UKP2J filters. I have two of each type. Which is the best type?
I was considering buying one of those units that split the telephone and dsl wires at the socket (cant remember the name) as they are the best way to separate the data.
Ill have a look at the socket wiring later on and get back to you.
Thanks for the advice Anotherone.
Sorry godsell4 I dont have any router stats from when I was connected with Tiscali.
ps. my sync speed went up again to 2027kbps today.
07-05-2009 6:06 PM
10-05-2009 3:33 PM
Does anyone have any suggestions regarding what I should do to lower my SN Margin?!?
- « Previous
- 1
- 2
- Next »
