Line Speed slower than expected
- Line Speed slower than expected
05-05-2009 2:25 PM
Thanks in advance.
Re: Line Speed slower than expected
05-05-2009 2:30 PM
Can you post the line stats from your router? Have a look here if you don't know how to get it http://www.kitz.co.uk/adsl/frogstats.php
Also what does the BT speedtester give your profile as? http://speedtester.bt.com/
Someone then might be able to point you in the right direction.
05-05-2009 2:32 PM
Can you try unscrewing the faceplate from your master socket and then plug the filter into the test socket? You should see it on the right hand side.
Looking at yo0ur line, your sync speeds are currently 1760Kbps, which may improve once you're plugged into the test socket (because there appears to be a level of noise on your line).
05-05-2009 2:49 PM
Could it be dodgy wiring?
Also ive got a Thompson router which isnt on that list adiewoo
05-05-2009 2:52 PM
05-05-2009 2:58 PM
Test1 comprises of Best Effort Test: -provides background information.
Your DSL connection rate: 1888 kbps(DOWN-STREAM), 448 kbps(UP-STREAM)
IP profile for your line is - 1000 kbps
Actual IP throughput achieved during the test was - 303 kbps
05-05-2009 3:00 PM
There wouldn't be any noticeable speed difference as it takes a few days for the profile to lift.
05-05-2009 3:02 PM
Quote from: dtrumble I did what you said Jameseh, and it did raise the line speed, but only to around 1.1 Mbps
Was that the sync speed reported by your router or the BT speedtest or the actual throughput reported by a speed test?
05-05-2009 3:07 PM
adie:quote
05-05-2009 3:13 PM
Uptime: 0 days, 0:16:53
DSL Type: G.992.1 annex A
Bandwidth (Up/Down) [kbps/kbps]: 448 / 1,888
Data Transferred (Sent/Received) [kB/kB]: 0.00 / 1.00
Output Power (Up/Down) [dBm]: 12.0 / 17.0
Line Attenuation (Up/Down) [dB]: 31.5 / 60.0
SN Margin (Up/Down) [dB]: 16.0 / 15.5
Vendor ID (Local/Remote): TMMB / TSTC
Loss of Link (Remote): 0
FEC Errors (Up/Down): 0 / 227
CRC Errors (Up/Down): 0 / 1
HEC Errors (Up/Down): 0 / 1
when plugged into test socket.
Link Information
Uptime: 0 days, 0:00:12
Bandwidth (Up/Down) [kbps/kbps]: 448 / 1,760
SN Margin (Up/Down) [dB]: 16.0 / 15.0
FEC Errors (Up/Down): 0 / 0
CRC Errors (Up/Down): 0 / 0
HEC Errors (Up/Down): 0 / 0
when plugged in normally.
05-05-2009 3:19 PM
BT set an IP Profile (as reported by the BT speedtest) which is the speed they think your line can reliably sustain without too many errors. Your line will be restricted to that speed.
You need to work through the guidance you will be given in here to try and improve the sync speed and keep it stable. When you achieve that increases in test results will follow.
05-05-2009 3:27 PM
05-05-2009 3:31 PM
The bit which puzzles me is an attenuation of 60dB when you are so close to the exchange.
Do you have any neighbours with broadband - if so see if you can get the attenuation from their router
05-05-2009 3:48 PM
05-05-2009 3:51 PM
Before you switched to the test socket there were errors recorded by your router - how long had it been connected - it's showing only 16 minutes, is that right?
If you could leave it connected to the test socket and post the stats after say a day we can see how many errors are occurring.
