Line Speed dropped
Extooth
Line Speed dropped
My line speed has dramatically reduced since when i first joined up with plusnet. I was usually receiving around 7mbps however this has dropped now to around 5.2. Since my line speed is so low to start with, I can really feel the dips when doing online gaming or watching youtube videos for example. I have tried several times throughout the day to use the chat service but every time i visit the website it just says it is unavailable, phoning is not an option.
I have tested around religiously with settings and to no avail, the speed seems to be limited to 5.2 mbps.
Tests ive done:
- Firmware updates on router/modem. - All settings are correct and in working order.
- Directly using the master socket (My house does not have a normal BT faceplate with a master socket, so I used the closest thing to it that has the BT logo on it.)
- Only connecting via ethernet.
- BT Wholesale Speed test.
Some Line details:
SNR Margin
11.5
25.0
db
Line Attenuation
22.5
15.0
db
Data Rate
8128
448
kbps
Max Rate
10560
1160
kbps
POWER
19.5
12.0
dbm
CRC
0
0
Speed test results close to this everytime: http://speedof.me/show.php?img=161122015708-404.png
This problem has been around now for a few months, and im starting to pull out my hair over it. There is no other thing i can think of that ive not yet tested.
Regards,
Chris
Update: forgot to mention I use my own router, a Asus rt n66u together with a td 8817 modem. I have tested with a bt router and plusnet router with similar results, all around the 5.2 mbps mark, never higher.
Moderator's note by Mike (Mav): I have edited the post to make it more readable by getting rid of the extraneous characters.
Gel
Seasoned Pro
Fixes: 14
Re: Line Speed dropped
Extooth
Hehe, recently moved house and I was used to the same, was a nightmare when you're more than 1 person.
Browni
Aspiring Hero
Fixes: 47
Have you tried a different speed tester?
That one massively underrates my connection.
http://speedof.me/show.php?img=161122170853-5303.png
21/5 compared to
I must have been really bad in a previous life as this was my 3rd ISP in a row that used lithium.
Now you're stuck with me because my new ISP doesn't run a forum Cheesy
Extooth
Speedofme and speedtest both give me similar speeds each time, however the bt wholesale test commonly shows me in the area of 4.65 mbps.
