Line Speed // IP Profile
- Line Speed // IP Profile
16-11-2011 12:43 PM
Download speed achieved during the test was - 437 Kbps
For your connection, the acceptable range of speeds is 50-500 Kbps.
Additional Information:
Your DSL Connection Rate :8128 Kbps(DOWN-STREAM), 448 Kbps(UP-STREAM)
IP Profile for your line is - 500 Kbps
I have read the sticky topics regarding line speed and IP profiles and found them very informative. What I'd like to ask is if there's anyway I can see when the instability that apparently caused the speed cap of 500kbps happened? The issues started last night out of the blue, one minute everything was fine, and then everything took an absolute age to load. At first I thought someone might be nicking my bandwidth (I live in an apartment complex, about 30 different wireless routers show up if you scan), so I changed my wireless security settings and all that, only to do the BT line test thing this morning and see that tragic 500kbps speedcap.
As I say I'm not really sure when the apparent instabilities happened and I'm not 100% sure on the best way to try and get it back to normal. Should I just use everything as normal or should I lay off the downloads?
Any help very much appreciated.
Re: Line Speed // IP Profile
16-11-2011 3:45 PM
Given your current sync speed I've requested an SNR reset for you, that should retrain the line to its fastest possible speed. It should take effect within the next couple of hours.
Hope that helps.
16-11-2011 4:33 PM
17-11-2011 11:36 AM
Download speedachieved during the test was - 428 Kbps
No improvement from yesterdays results... still got the dial up speeds.
17-11-2011 5:18 PM
17-11-2011 5:55 PM
How long will it take?
18-11-2011 10:01 AM
18-11-2011 10:05 AM
Quote from: Matt Order placed - it'll complete on the 25th
Nice one, thanks.
Am I going to be stuck with 500kbps speed until then? Or will this IP profile reset before then?
18-11-2011 10:09 AM
18-11-2011 11:15 AM
18-11-2011 11:44 AM
18-11-2011 4:34 PM
If there's anything else I can do to aid the profile reset e.t.c please let me know.
18-11-2011 6:11 PM
Quote from: Schadenfreude I'll do that daily then
Once shoud be enough, unless your not happy with the result
To be is to do - Kant
do be do be do - Sinatra
