Line Speed Dropped
- Line Speed Dropped
Line Speed Dropped
06-04-2013 9:59 AM
ADSL Link Downstream Upstream
Connection Speed 3574 kbps 444 kbps
Line Attenuation 56.0 db 31.7 db
Noise Margin 9.0 db 20.1 db
How do I get back to the higher speed, do I need to switch of the router for a while and let the signal reset, or do I have to get someone to intervene?
Re: Line Speed Dropped
06-04-2013 10:40 AM
Have you looked at your wiring? Is the router connected to the Master Socket? Do you have any extensions?
06-04-2013 10:59 AM
I was getting 4Mb with 6 db early in the week, but maybe there has been an effect from a disconnection on Thursday?
06-04-2013 11:12 AM
Yesterday 09:57 3062 kbps (383kB/s)
Wednesday 18:41 3314 kbps (414kB/s)
Wednesday 09:30 4055 kbps (507kB/s)
Tuesday 21:53 3738 kbps (467kB/s)
Tuesday 14:26 3815 kbps (477kB/s)
Tuesday 12:19 3745 kbps (468kB/s)
Tuesday 11:26 938 kbps (117kB/s)
Tuesday 11:24 945 kbps (118kB/s)
Tuesday 11:23 944 kbps (118kB/s)
Monday 21:52 2826 kbps (353kB/s)
Monday 11:32 2789 kbps (349kB/s)
Monday 10:41 2825 kbps (353kB/s)
A bit of fiddling around on Monday, but this was all done with a SNR of 6db until weds evening
06-04-2013 2:41 PM
06-04-2013 3:08 PM
Any idea?
06-04-2013 8:02 PM
Leaving things alone for a few days should demonstrate stability and give the DLM scope for reducing target SNRM again.
06-04-2013 8:24 PM
06-04-2013 9:40 PM
The ip profile, according to BT, has dropped from 4Mbps to 3Mbps, and the upload has dropped a bit too.
I'm hoping it will come back up again if I leave it alone for a few days, but if you have any other ideas, I'm all ears.
09-04-2013 11:41 AM
Doesn't look too bad but it seems interleaving has been removed from your line which has affected the stability for the worse. It should sort itself out within the next couple of days but if it doesn't please give us a shout and we'll put it back on for you, see if that improves things.
