Line Reset please?
- Line Reset please?
Re: Line Reset please?
17-05-2014 4:24 PM
17-05-2014 6:22 PM
Well that is cheery news!
I have just looked back through the thread the goal posts have most certainly moved! The report is not your synch speed but your data throughput speed.
talking of which, we've not seen your router stats yet, could you please post them on here? This will show what your line is doing, give a pointer to what it ought to do and quite importantly what is the error rate. Also from the synch rate, I'll be able to tell if your data speed is about right... or not!
Kevin
17-05-2014 7:42 PM
17-05-2014 8:49 PM
Thanks for trying - can I offer some suggestions...
1. Router stats, can you please try copying and pasting the stats from the router web page into the post. From the screen grab, I can only see some of the stats.
2. Router Stats graphs. The most interesting graph is the DS Noise graph. You can right click on this and select over plot DS synch, that way one can see the most important / useful information in one place.
Kevin
17-05-2014 9:16 PM
As requested Kevin
But I can't find the DS noise graph - is it the noise margin graph - I've added that and as you can see something drastic has happened!
17-05-2014 9:37 PM
Quote from: Mikejstephens Uptime: 0 days, 0:33:29
DSL Type: ITU-T G.992.1
Bandwidth (Up/Down) [kbps/kbps]: 800 / 928
Data Transferred (Sent/Received) [MB/GB]: 62.66 / 1.26
Output Power (Up/Down) [dBm]: 12.5 / 17.3
Line Attenuation (Up/Down) [dB]: 31.5 / 48.5
SN Margin (Up/Down) [dB]: 11.0 / 29.6
Loss of Framing (Local/Remote): 0 / -
Loss of Signal (Local/Remote): 9 / -
Loss of Power (Local/Remote): 0 / -
Loss of Link (Remote): -
Error Seconds (Local/Remote): 2,580 / -
FEC Errors (Up/Down): 1 / 0
CRC Errors (Up/Down): 0 / 0
HEC Errors (Up/Down): - / 0 generateTasks()
@Mods I know re-quoting the whole of the previous post breaks the rules, but I thought I'd make it easy for everyone to read.
@Mike,
This did not happen when you altered the graphs - yes this is the right one - the event happened around 20:40 several posts back. This is very interesting and is what we need to be looking out for. Right now your DS synch is the pits and the SNRM is sky high. The DS is nearly the same as the US.
Your line should be capable of doing around 5.5Mbps, which prior to 20:40 is about where it was. At that time I suggest that there was a noise event which caused a loss of synch, followed by a resynch at a very low speed. The Error seconds looks wrong too - it is 10 minutes more than the reported uptime. You need to get control of your line so that it comes back to a usable state, without upsetting the DLM.
Until you get this bottomed out and resolved, it is important that YOU CONTROL as many of any router restarts as you can - this will avoid upsetting the DLM.
1. Log into the router
2. Go to the home page and click on disconnect
3. Wait for the button to change to CONNET
4. Wait a couple of minutes then power off the router
5. Have a cup off coffee
6. Power the router up
7. Log into the router and click CONNET
Then get the router stats and post them back here please. If you could format them as above please that would be useful.
I think there is some evidence for REIN here, but I need to see a clearer picture first.
Kevin
17-05-2014 10:58 PM
Uptime: 0 days, 0:08:21
Bandwidth (Up/Down) [kbps/kbps]: 864 / 4,608
Data Transferred (Sent/Received) [kB/MB]: 282.34 / 1.24
Output Power (Up/Down) [dBm]: 12.5 / 19.3
Line Attenuation (Up/Down) [dB]: 31.5 / 49.5 SN Margin (Up/Down) [dB]: 10.0 / 5.3
Loss of Signal (Local/Remote): 0 / -
Error Seconds (Local/Remote): 1 / -
FEC Errors (Up/Down): 0 / 287,259
CRC Errors (Up/Down): 0 / 1
HEC Errors (Up/Down): - / 1 generateTasks()
18-05-2014 6:42 AM
Also the 10.2 technicolor firmware contains a newer ADSL driver than the 8.4 firmware, so the 10.2 firmware might be more stable.
18-05-2014 8:04 AM
Uptime: 0 days, 0:08:15
Bandwidth (Up/Down) [kbps/kbps]: 864 / 5,088
Data Transferred (Sent/Received) [MB/MB]: 5.09 / 28.34 Output Power (Up/Down) [dBm]: 12.5 / 19.6
SN Margin (Up/Down) [dB]: 11.0 / 6.0
Loss of Framing (Local/Remote): 9 / -
Loss of Signal (Local/Remote): 1 / - Loss of Power (Local/Remote): 0 / -
Error Seconds (Local/Remote): 44 / -
FEC Errors (Up/Down): 8 / 302
HEC Errors (Up/Down): - / 4 generateTasks()
18-05-2014 9:20 AM
Had the router disconnected and reconnected at a very low speed just after 8am this morning? If not, you shouldn't really reboot the router (safe shutdown dance or not) after every disconnect - only if it has ended up connected at a very low speed.
18-05-2014 12:10 PM
These figures look better. As ejs states unless the new synch speed is poor, do not reboot the router again.
4Mbps to 5Mbps is reasonable level from which to look into the underplaying problem. Please keep the monitoring running, look to try to match shifts in SNRM to things being switched on / off.
I know that you've said that your internal wiring has been eliminated, however can you please describe it? How many extensions are there? Are they daisy-chain wired or star wired? Is the bell wire connected? Can you confirm that either all extension phones are filtered or that the extension wiring is off a filtered nte5 face plate?
Kevin
18-05-2014 1:04 PM
22-05-2014 3:23 PM
The router hasn't been rebooted or used by me since last Sunday.
Uptime: 1 day, 0:08:54
Bandwidth (Up/Down) [kbps/kbps]: 864 / 5,152
Data Transferred (Sent/Received) [MB/MB]: 14.43 / 87.37
Output Power (Up/Down) [dBm]: 12.5 / 19.9
Line Attenuation (Up/Down) [dB]: 31.5 / 50.0
SN Margin (Up/Down) [dB]: 10.0 / 4.9
Loss of Framing (Local/Remote): 123 / -
Loss of Signal (Local/Remote): 17 / -
Error Seconds (Local/Remote): 66,149 / -
FEC Errors (Up/Down): 1,700 / 9,376,999
CRC Errors (Up/Down): 1,805 / 31,293
HEC Errors (Up/Down): - / 440,373
generateTasks()
22-05-2014 4:33 PM
I wondered where this one had gone to. can you please update me where you are on engineering visits please? A fair few posts ago (17th) there was a reference to an engineer visit "on Friday" - was that last Friday or is it tomorrow?
If last week, what was done?
Your recent stats are much improved over your sub 1Mbps situation from last week. The line is right on where it might be expected for the current attenuation, however I note it has been varying quite a bit between 48.5dB and 50dB. The BT Profile is right on the nose for your current synch rate. Do you know what the PN profile is?
The line error rates are quite high too. As you still running router stats please? Do you have an open fault ticket?
Kevin
22-05-2014 4:44 PM
