Line Errors
GeordieMark
Line Errors
Afternoon guys,
Noticed yesterday there are quite a few errors building up, unfortunately i can't get an exact number as I'm at work. I was wondering if one of you guys could have a quick look at the line and see what you think?
I'm getting FTTC installed next week so I don't know if it is still going to be an issue, I'd just feel happier if I knew the d-side of the line was alright so it didn't cause any issues with the fibre install.
Thanks in advance.
Plusnet Staff
Plusnet Staff
Fixes: 5
Re: Line Errors
Hi GeordieMark,
I can't see any errors from this side, at the time of testing. From what I can see, based on those figures, both E & D-sides are both ofn pretty good quality, they have to be to keep your line error free on a 3db profile Smiley
Stats are attached.
Chris Pettitt
Cloud Environments Engineer
GeordieMark
Re: Line Errors
Thanks Chris, good to know  Smiley
Yes it has *touch wood* been quite stable on 3db so I'm happy with that, looking forward to see what I get on fibre next week  Grin
