Line Drop Outs-any ideas?
reader
In a morning at approx the same time I get a drop out which only lasts a few seconds before correcting itself.  This has only happened since the 11/1/16 when openwoe repaired a line fault. down the close.
Its more annoying than troublesome but as I am at a point of considering keeping PN (due to poor back up from openwoe) as my provider I am curious what could be causing this
cedlor
Re: Line Drop Outs-any ideas?
How are you monitoring that. does your whole service cease or is it just the wifi?
Would normally ask you to do a quiet line test  17070 option2 on a corded phone when the broadband was out but if its just seconds Huh?
reader
I am normally changing to a new web page and the router sign in page appears.  If I do nothing page comes up after a period (sometimes less than a minute).  If I look at the router I can see it restablishing the connection.    I suppose if I had phone handset next to pc I could check landline as you suggest if I was quick enough
