Line Drop Outs-any ideas?
- Re: Line Drop Outs-any ideas?
27-01-2016 7:44 AM
In a morning at approx the same time I get a drop out which only lasts a few seconds before correcting itself. This has only happened since the 11/1/16 when openwoe repaired a line fault. down the close.
Its more annoying than troublesome but as I am at a point of considering keeping PN (due to poor back up from openwoe) as my provider I am curious what could be causing this
Message 1 of 3
(785 Views)
2 REPLIES 2
27-01-2016 12:25 PM
How are you monitoring that. does your whole service cease or is it just the wifi?
Would normally ask you to do a quiet line test 17070 option2 on a corded phone when the broadband was out but if its just seconds ????
Message 2 of 3
(428 Views)
27-01-2016 2:19 PM
I am normally changing to a new web page and the router sign in page appears. If I do nothing page comes up after a period (sometimes less than a minute). If I look at the router I can see it restablishing the connection. I suppose if I had phone handset next to pc I could check landline as you suggest if I was quick enough
Message 3 of 3
(428 Views)
