Line Attenuation?
- Line Attenuation?
Line Attenuation?
15-09-2008 8:31 AM
I've posted elsewhere about sync problems, but I've just noticed that when unplugging and re-setting the router back up that the attenution has gone down to 21db and my sync is up at 8096kbps!
Re: Line Attenuation?
15-09-2008 8:58 AM
Just count yourself lucky if it holds at that I guess...
15-09-2008 9:17 AM
It might be an idea to try rebooting your router and see if it continues to hold. It does sound rather strange though
I've seen a reporting bug in the past where a very low attenuation figure has been reported, but the sync speed didn't change.
15-09-2008 9:27 AM
Incorrectly connected extension wiring could potentially alter your attenuation figures (in an upwards direction!) If you've recently 'fixed' something then this could be the cause.
B.
15-09-2008 9:31 AM
15-09-2008 9:49 AM
I haven't changed any wiring, or anything, up until last night when I have removed the face plate from the master socket, and plugged the filter into the service socket and then just the router into that and only the router.
It didn't make any difference last night, I was still only syncing at 1000kbps or less and having drops every now and then.
I then this morning swapped the filter and got the low attenuation, and sync at 8000kbps+
This has held for 30 mins with no use of the internet, me just sat here watching TV. I have now come to check for replys and routerstats shows 3 drops and sync back at 832kbps and attenuation at 55db????
any ideas?
15-09-2008 9:52 AM
is it likely that a faulty filter or filters could be cause a high attenuation?
15-09-2008 9:55 AM
Have you tried using the test socket, which you can find if you unscrew the faceplate from your master socket. Using this eliminates your internal wiring which can be the cause of a fault.
15-09-2008 10:07 AM
15-09-2008 10:13 AM
Is there any chance that you could borrow a modem or a router from a friend and see if your connection holds?
If it doesn't, then you'll need to raise a fault by going to http://faults.plus.net
It shouldn't be the filter as you've tried 3 of them.
15-09-2008 10:21 AM
could it be a BT line problem?
15-09-2008 10:58 AM
16-09-2008 8:09 PM
Connection Speed
8128 kbps down
448 kbps up
Line Attenuation
20.0 db down
12.5 db up
Noise Margin
15.5 db down
22.0 db up
only problem now is this has been steady for most of the day, yet my profile is still down at 250K! any idea how long it will take to come back up? or if anyone can move it back up quicker?
17-09-2008 10:48 AM
17-09-2008 12:27 PM
