Line Activation
- Line Activation
- « Previous
- Next »
Re: Line Activation
23-12-2010 12:13 PM
Hi Graeme,
I've just checked your line and see sync at 19840 and profile of 17000. If you're not getting that throughput then I would check here for some tips. Also, were those tests done wired or wireless?
Jojo
Jojo
Message 31 of 35
(248 Views)
Re: Line Activation
23-12-2010 4:16 PM
Hey Jojo,
My Laptop is connected wireless at this point but from looking at the exchange where I live it says there is a current problem with the broadband and home phone, due to the recent traffic management platform problem and call processing.
Any ideas when this will be sorted?
Regards,
Graeme
Regards,
Graeme
Message 32 of 35
(248 Views)
Re: Line Activation
23-12-2010 4:34 PM
You need to run a speed test using a wired connection. The reason for the speed drop is very likely to be at your end.
Message 33 of 35
(248 Views)
Re: Line Activation
24-12-2010 3:06 PM
Hi gpavlovic,
The issue with the traffic management is now cleared and it wouldn't have affected you in that way. I would suggest you run a speed test with the ethernet. My own speed test results are much slower on my wireless too.
Jojo
Jojo
Message 34 of 35
(248 Views)
Re: Line Activation
24-12-2010 6:43 PM
Quote from: pierre_pierre the BT test on my line gives stupid result, try http://www.mybroadbandspeed.co.uk/, my results are backed up by a SamKnows monitor I and on
I am sure these are correct either?
Would be nice though
Puddy
Message 35 of 35
(248 Views)
- « Previous
- Next »
