Limited speed between 12am and 7am (0mbps) !!
- Limited speed between 12am and 7am (0mbps) !!
05-04-2012 12:46 PM
Why is my speed being restricted at night time between midnight and 8am? As I thought I still had unlimited access between these times and there was no usage allowance.
OK I get that you restrict it between 8am and midnight as I have used up my peak-time usage but it does not seem fair otherwise!!
Please look into this.
Message 1 of 5
(1,143 Views)
4 REPLIES 4
Re: Limited speed between 12am and 7am (0mbps) !!
05-04-2012 1:23 PM
If you hit your usage allowance on any of our current residential products then you'll be restricted 24/7 until your next billing date. You can add more usage at £5 per 5GB block if you like.
http://www.plus.net/support/broadband/products/res_broadband_faq.shtml#overAllowance
Message 2 of 5
(503 Views)
05-04-2012 3:39 PM
I'm on Fibre Extra.
New month starts on Saturday so hopefully the speed will be lifted on Saturday?
Message 3 of 5
(503 Views)
05-04-2012 4:41 PM
That's correct - usage will reset early Saturday morning for you.
Message 4 of 5
(503 Views)
05-04-2012 5:31 PM
Why not just restrict speeds in the peak times and allow unrestricted speeds in off-peak?
Message 5 of 5
(503 Views)
