Limited Connectivity
blade4life
I have been a Plusnet Fibre Optic customer for 6-8 weeks now. Everything was working great, but in the last week I have been having a lot of connection drop outs.
I am running Windows 8  and it says the connection is "Limited". This problem usually resolves itself within a few minutes.
The problem really came to a head this morning when I could not get online for around 45 mins
Is there any fixes for this?
I wish I could offer more technical information, but I am a bit of newbie to this.
adagio
Re: Limited Connectivity
How is your computer connected to the router?
blade4life
I am connected wirelessly
itsme
That's your problem. The PC is losing the connection with the router. How far away is the router, can you move it closer? When you see the problem is the microwave oven being used?
blade4life
I'm not sure it is just down to the wireless. As everything in the house goes down I.e TV, sons xbox, phones etc. and as for something causing the interruption, I can't think of anything causing it, as it went down in the middle of the night when it was just me awake.
Fixes: 62
please clarify the phones part - is that the voip phones or is it the normal phones
blade4life
As in wifi on mobiles.
Fixes: 62
Have you looked at the router log to see if it shows a PPP drop
itsme
Limited connectivity is when the device assign its own IP address because the router has not. You are losing the wifi connection
Looks like older microwaves can certainly interfere: http://en.wikipedia.org/wiki/Electromagnetic_interference_at_2.4_GHz#Microwave_oven
Perhaps try a different (newer) microwave and see if it makes any difference?
Pedro
Wireless does not assign itself an IP address, you either are connected to an access point or you aren't.
In windows 8, the limited wireless icon means you are connected to the router, but there is no internet connectivity, i.e. like OldJim suggested, the connection dropped. I see this when I disconnect the PPP session manually or when wireless goes up after rebooting it and before it reconnects to +net.
The only way he'd see a 169. IP address, is if he had a NIC wired to something, assuming there is one on his windows 8 PC, as it would take over from the un-associated Wifi interface.
A look at his connection graph would probably end the speculation  Cheesy
Then I shall oblige - I hope these are all manual router reboots though...
<img src="http://community.plus.net/visualradius/generated/image13763188013712.png"/>
blade4life
Wow thats an interesting graph....... None of these are unecceasry manual reboots though. The only time I have restarted my router is when my connection drops out for an extended period.
In that case, as there's no extended dropouts showing on that graph I suspect it is the wireless. Do any of the drops coincide with the times you weren't able to get connected? Also when you're having the connectivity issues do you see the Technicolor Gateway page or the browser's no connection page?
